Fan doesnot come on - Heating & Cooling
  • 382 Answers
Dear sir
if you know how to read a electrical tester then open control panel box and find out there selector switch and check electricity is reaching till selector switch then find out fan motor wire after that tester turn to continuity testing mode and check continuity between all wire of fan motr if there is continuity then it,s mean motor winding is ok and problem in other device then check one bye one all device . if there is no continuity in fan motor wire then it,s mean fan motor is faulty and it need to replace .it,s up to if you can do that by your self or take help from a technician.
hope answer the question
thank you
please vote!
Posted on Oct 03, 2010
I HAVE A WHIRLPOOL MODEL GI6FDRXXY 07, AND THE EVAPORADOR MOTOR DOESNOT WORKING... IT NO RECEIVE THE 12 V... WHY? A NEED A WIRING DIAGRAM... TO CHECK...
If your evaporator motor is not working, you are so correct. The air circulated in the refrigerator is due to the evaporator motor fan. If left to operate without a fan to provide a heat load for your compressor, it could cause your compressor to fail. Your problem is most likely the defrost sensor inside the cover of your evaporator. It is probably stuck open and will not put power to your evaporator fan. Take you model number to Searspartsdirect.com and find the defrost sensor for your refrigerator and replace it.
Hope this helps
Dec 13, 2014 | Whirlpool GI6FDRXXY
Blower fan doesnot work on 1995 cadillac eldorado...where do I find the fuse?
fuse panel label heater . check power at fan plug. maybe fan bad or fanswitch
Nov 20, 2010 | 1995 Cadillac Eldorado
05 vue ac problem, ac not cold at idle, blows cold while driving, had checked freon is full, expansion valve was replaced, because high side flutters and low side does same. seems that compressor doesnot...
Hello, Are the cooling fan(s) coming on with the truck in park and the engine at idle? If the cooling fan(s) are not working A/C will not cool with truck setting still.
Oct 02, 2010 | 2005 Saturn VUE
The display doesnot come and processer and powersupply fan also doesnot move?
If the fans do not "spin", nor even "rock" slightly, just once, when you connect the AC power-cable, or press the ON/OFF button, then it is the power-supply that needs to be replaced, at least temporarily, to "trouble-shoot" the problem.
Sep 09, 2010 | Intel DG31PR Motherboard
How to Diagnose a Cooling fan
if the fan doesnot run with the engine running and the A/C on poss bad fan or sensor or relay
Aug 25, 2010 | 1995 Honda Accord
My HP Pavilion 21020n has given me an error message stating my system fan failed, where can I find the system fan?
open up the chasis and on top of the cpu the fan is located
try to reseat the cables of the CPU fan located beside the fan and if it doesnot work get a new compatible fan and get it installed by a local tech
Mar 11, 2010 | HP Pavilion a1010n (PS563AA) PC Desktop
My air condition is working but the fan is not turnig
fan has to turn for system to function properly turn off breaker see if fan turns if not bearings are shot if it does maybe fan motor bad or wiring issue! Good Luck!!!
Jun 24, 2009 | Goodman CKL36AR36 Air Conditioner
Battery backup problem and processor fan doesnot work properly
You should take your computer into an authorized IBM repair depot. Do you live in Canada? CompuFirm can assist you, we have repair depots all over canada visit www.compufirm.net to view our locations.
I would take it in for repair quick because the fan not working could cause system failure.
May 31, 2009 | Lenovo ThinkPad R61 Notebook
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
