Plz i have dell gx620 optix tower with this chip it start game like medal of owner and it crach down the system hangup
    President:
  • 2,571 Answers
It all depends on what graphics card you have, does it meet the minimum specs???
How much ram??
what CPU?
Posted on Oct 03, 2010
My gx620 thermal fan overheats
A) FOLLOWING Anti-Static Procedures;
1) Clean the inside of the computer out
2) Replace the Thermal Paste on the Processor (CPU)
THOROUGHLY clean top of CPU (Processor), and bottom of Heatsink.
PROPERLY apply fresh, new Thermal Paste.
http://www.hardwaresecrets.com/article/274
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx620
Click on the blue ->
Dell Optiplex GX620 System User's Guide (5990KB)
Using Mini Tower Computer as an example;
In the list click on;
1) Removing the Computer Cover
2) Processor
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
Dell optiplex GX620 doesnt start
1-3-1 through 2-4-4
Memory not being properly identified or used
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
Feb 12, 2013 | Dell OptiPlex GX620 PC Desktop
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
Dell Optiplex GX620 Desktop PC's south bridge IC heats up abnormally...
Check the capacitors on the motherboard, Dell had a BIG problem with faulty capacitors on the GX270, GX520, GX620, GX745 and GX755 units. The parts would cause the unit to either not boot at all or lockup booting or running programs. I would bet you have some that are just beginning to fail and the motherboard power is not stable which would mean the chips are not getting enough power. Here is a link to an article about the issue and what to look for on your board.
http://www.ccl-la.com/blog/index.php/dell-optiplex-gx620-motherboard-repair/
I hope this helps you out, if so please rate my solution.
BuddyMc
Jun 30, 2011 | Dell OptiPlex GX620 PC Desktop
Dell Opitplex GX620 - "System
If you pull the side access cover off the computer tower, look inside and you will see a large circuit board, that is the Motherboard, on that board you will see a button sized silver battery, this is the battery backup for the "CMOS", and keeps the time and other memory functions alive. Carefully pry out the old battery and replace it with a new one, any Radio Shack or electroinics supply will have the battery. The battery number is on the battery. Make sure to install the battery exactly as it came out, it has a positive and negative side, write it down.
Jan 04, 2011 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Apr 24, 2009 | Dell OptiPlex GX620 PC Desktop
Computers & Internet Logo
David Payne
David Payne
