Question about Admiral Washing Machines
My admiral washer drains while it is filling. What is happining and how do i fix it? ckjcecil@aol.com
    Sergeant:
    Champion:
  • 351 Answers
Drain hose maybe to low water is syphoning out
Posted on Oct 03, 2010
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
My wash machine tries to fill, but it sounds like the pump is pumping it out as fast as it fills.
The number one suspect reason for simultaneous fill and drain would be that your washing machine drain hose is inserted into your wall drain too far. The drain stack pipe in the home should be as high on the wall as the top of the washing machine main top/lid, and the hose from the washer inserted no deeper than 10" and properly secured to one of the adjacent water shut offs with a zip tie. If this is your issue, your drain system in the home is creating a siphon through the washer drain hose and literally sucking the water out of the washer. Pleazer Appliance...
Apr 15, 2014 | Admiral Washing Machines
Washer machine is draining while it is filling with water.
You may have a condition known as "siphoning". This is usually caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain (siphon) as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Aug 04, 2010 | Admiral AW22 Top Load Washer
Admiral LNC6762B water keeps running when starting
try these one of the following is not operating properly.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Oct 19, 2009 | Admiral AAV7000A
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Washer will not drain
clean pump and drain hose
Aug 26, 2009 | Admiral AW22 Top Load Washer
Doesn't fill all the way
the solution to the problem was....a few days before we noticed the washer was not filling all the way, the plumber had come over to clear our pipe, because it was not draining. He had tightened the clamp we were using to keep the pipe in place too tightly, it was air tight and it was creating a vacuum and siphoning the water out when it got to a certain level. We took the clamp off since there was no longer a need for it and the washer fills up and drains as it should.
Dec 10, 2008 | Admiral AAV7000A
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
