Question about LG Electronic Window Air Conditioner
Cutting of thermistor wire by rat
My AC thermistor wire has been cut by a rat thus ac is throwing only hot air and  not  coolling i fix the it
  • 828 Answers
If you have enough loose end on the wire you can make a splice and solder the point. Insulated it well with electrical tape. The alternate is to replace the thermistor which and more than likely be ordered by model number and serial number of your unit.
Posted on May 28, 2008
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
1997 Nissan 4 cylinder truck AC works excellent throwing snowballs cold air, then it will blow hot air. Relay switch and clutch has been replaced....Did not fix problem!
sounds like compressor isn't working properly or heater vacuum is opening vent to heater core.try turning on ac and if it cuts on and off repeatedly every few seconds the freon level is not correct or high pressure switch may not be working make sure radiator fan comes on when ac is on.if all this is working properly check vacuum hoses to heater may be opening vent doors to heater.hope this helps
Aug 11, 2010 | 2005 Nissan Altima
How can i unplug the rear ac of a gmc 1997
you reay can't unless you cut wires I would recemend putting 134 a in it an it will blow cold again it sounds like it is just low on gas
Aug 01, 2010 | 1997 GMC Suburban
The ac quit fan, no air. The 30amp
check the ac blower transistor under passenger side of dash behind the blower motor. on my 2003 compressor would not cut on , front blower only operated on high an blew hot air, rear blew on all speed but only hot air. $58.00 at dealer plus tax. 15 minute fix. there is a video on youtube that documents the process. just fixed today
Jul 05, 2010 | 2006 Honda Odyssey
AC is not working properly
this first to do is check wiring to compressor clutch,when ac is not working check the ac clutch it should be engaged,test for power and ground at ac compressor clutch, you may have a bad wire to clutch or a bad compressor clutch,8226523.pngc97e168.giff41b56b.gif672ce29.gif
Mar 04, 2010 | 2003 Nissan Pathfinder
Coil on ac is cut by the surrounding wires in 4
If you mean smashed and not popped with freon lost them its likely ok just not pretty
Dec 30, 2009 | Heating & Cooling
Climate control on a 98 Pontiac Bonneville
if the compressor suction line is getting cold and sweating and the line going out to condensor is hot - the compressor is working - the electric door to cut off heat is stuck or motor coupling could be broke - this unit under the dash can be hard to get to - i have installed a valve in heater hose to cut off hot water in summer on older cars - cheap fix - unless you want to take out dash
Sep 11, 2009 | Heating & Cooling
AC compressor cuts on and off
But does it work fine? it's normal for the compressor tu turn on and off randomly, is it cooling fine??
Jun 29, 2009 | 1995 Chevrolet Camaro
LG Electronic Window Air Conditioner Logo
242 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
