WASHER WORKS FINE UNTIL IT REACHES LED 6-MIN. THEN MOTOR CLICKS ON AND OFF.AFTER AWHILE IT STOPDPS CLICKING AND WILL DRAIN AND SPIN BUT NOT RINCE.
  • ccgall1950 Oct 03, 2010
    general electric WJSE3110A0AA
    IT VERIFIED WHAT I THOUGHT.
    Top Expert:
  • Washing Mach... Master
  • 80,608 Answers
Need the specific make and model number of the washer
Posted on Oct 03, 2010
My washing machine won't spin when in a wash cycle but will spin on a spin cycle
???? ITS NOT SUPPOSE TO SPIN WHILE WASHING ? DO U MEAN ITS NOT AGITATING? THEN LOOK AT UR PRESSURE SWITCH AND UR CAM DOGS. MOTOR COUPLER OR BELT. NEXT UR CLUTCH BRAKE ASSEMBLY MAY BE BAD
Jun 09, 2015 | Hotpoint WF430 Front Load Washer
My washer runs fine until it reaches the rince cycle. As soon as the initial spin stops it freezes and won't fill for the rince cycle... Help!I need to play with the timer and need to pull on the...
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 19, 2011 | Frigidaire FEX831CS Top Load Stacked...
Washer makes very loud humming noise in spin cycle but does not spin..I removed clothes thinking it was very heavy and it did spin out but when I put clothes back it returned w/no spin and loud noise..now...
Either the control board or the motor has gone bad. Here is the diagnostic mode to run to look for the errors.
The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. • Press Pause/Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Repost the error codes here.
Feb 12, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washing machine not spinning AW1000W. It is about 6 years old. It appears to be responding to the control knob. It makes some slight clicking noises like a relay opening/closing It can be turned by hand...
Could be that the drive belt has broken or come off. Empty machine of washing and water, UNPLUG! turn on its side and look underneath to see of the belt is still located on the motor pulley.
Oct 15, 2009 | Tricity Bendix AW1000W Front Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Motor control board frigidaire
E59 No tacho signal for 3 seconds in other words sounds like a bad motor
Diagnostic Test:
? On non-digital display models, turn the Program Knob to start position, Drain/Spin.
? On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360?, turn the Program Knob to start position, Drain/Spin.
? Press Pause Cancel to turn off LEDs.
? Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
Exiting Diagnostic Mode
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED?s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
? Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
? Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
? Exit Diagnostic Mode to return the washer to normal operation.
Dec 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Washer agitates for a time then sputters. Does not spin
In sounds to me like you have a motor issue. We have found that on these particuliar models, that the motor tries to run in both speeds at the same time. If you already replaced the control board, then you will have to get a new motor kit. This kit includes directions as well as a new wiring harness and start capacitor. You would have to remove the old motor and rewire the wiring harness (instructions included with the kit) and add the new start capacitor (instructions also included). Job is'nt really that hard to do. Front cover would be all you would need to remove to get to all the parts. Good luck and let me know how it turns out or if you need any additional help. Jim
Sep 05, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
