Question about Dryers
My fan would run only on slow speed. I thought the switch may be the problem. My Hunter fan was equipped with a ZE-208 s5-1T that has 5 wires and need to know if and how to wire to a Zing Ear model 11.
  • sammyf Oct 03, 2010
    This Zing is wired to a rectangular cube capacitor looking box with a part number 74133-28. No I was going to replace the Zing with a new Zing, but maybe you can give me a better suggestion. Is this capacitor looking thing the brain you mentioned?
  • Kevin Naderi
    Kevin Naderi May 13, 2017
    is it 5uf 5uf 3.5uf
  • 10,515 Answers
First, check to see that the fan blades turn freely by hand and coast after being spun. If rotation is in any way stiff, this is a sign of dirty, dry, or gummed bearings, which can slow the motor. Sometimes the bearings can become tight and binding which can also be an issue.
Second, does the fan wobble at all? If for any reason the blade pitch is steeper on one or more blades than the motor is designed for, this will slow the motor. This can often be the cause of warping, or a blade being knocked off balance. This will also cause the fan to wobble or shake. See the section on balancing. You can bend the blades to a shallower pitch if they appear to be too steep, but be extremely careful as blade brackets can break easily.
Most ceiling fans made in recent years use permanent split capacitor motors, as they are efficient and reliable. However with age capacitors can drift in value. If the blades turn freely and are balanced, the cause of a fan running slowly is almost always a bad capacitor. The capacitor is a small black box or silver cannister with two or more wires attached, and is located inside the switch housing, motor housing, or inside a bell on top of the motor. It should be replaced with a capacitor of equal value, they are marked i.e. 6uf, 4uf, etc. Some fans have capacitors with two or more values, they should be replaced with the equivalent of those values by one or more capacitors.
Read :-
http://www.ceiling-fans-n-more.com/ceiling-fan-capacitors.php
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 04, 2010
    President:
  • 2,777 Answers
I believe the ZE-208s5-1T is just a regular pull style switch isn't it? Are you are trying to attach a "dimmer" style switch? I doubt the switch itself was the problem to begin with, probably the module that controls the fan is, the "brain" of the unit. Switches rarely fail, and when they do you usually can't select any speed at all. However I don't think you can replace that pull style switch with a dimmer style one, is that what you are trying to do?
Tim
Posted on Oct 03, 2010
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Fixya does not sell replacement zing ears. Check with a local appliance parts supplier.
Jul 05, 2016 | Hunter Dryers
What current Zinger switch would be used to replace a Zinger ZE 208S?
How many wires on the capacitor & which color wire goes into which slot of the pull chain switch?
Aug 12, 2014 | Hunter Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
5 wire, 4 speed Ceiling Fan Switch - Hunter
You should be able to assuming you have the correct switch. Don't use the 4 slot in switch.
Dec 29, 2012 | Dryers
Hunter fan switch doesn't work
I had this same problem. Home Depot and Hunter did not help me. I called Ken's Electronics in Kalamazoo Michigan Phone (269) 345-4609
website http://www.kenselectronics.com/index.html. He was excellent and very knowledgeable. Got repair part for about $7.00 and received it within two days. Great. I was so frustrated because it looks like I was going to have to purchase and install a whole new fan. Started to wonder if Home Depot and Hunter did this on purpose. Call Ken and he can help with questions and installation too.
Dec 01, 2011 | Hunter (25417) Ceiling Fan
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Hunter 93886 fan
You may be drawing to much amperage for the switch to handle both fans. You may be underwired if it is an old house. you can hook wires together without switch in place and see if everything keeps working but don't hook them together with the power on. Also don't run very long as the wires could heat up. Run for about 5 minutes and turn power off and check heating of wires.
Jul 28, 2009 | Hunter 235 Fan
Dryers Logo
775 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
