Question about Rowenta Irons
My Rowenta DX8750 leaks water like a sieve. How can I fix this problem?
2 Suggested Answers
brnspncr
  • 67 Answers
SOURCE: I have a Rowenta Power Glide 2. It leaks water
Could be a number of things BUT I STRONGLY RECOMMEND THAT YOU DO NOT USE IT!
All round it will probably cheaper to buy a new one from some discount sore or Wallmart had good cheap electrical appliance
Posted on Aug 07, 2009
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Leaky rowenta iron
Not a solution, but a word of caution. I have purchased several Rowentas, one more expensive than the previous one; all of them leaked. This time it went beyond a wet ironing board, there were sparks in the water tank near the temperature light. From the comments it seems the fix is GE.
Feb 15, 2012 | Rowenta Irons
I need to use the self clean on my Rowenta professional iron
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
Feb 14, 2010 | Rowenta Irons
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
Leaking
no the seals have gone, if it is under warrenty take it back
May 14, 2009 | Rowenta Professional DX8900 Iron
Rowenta model 1700W. Water leaks out front of iron
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
Iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Sep 26, 2008 | Rowenta Power Duo Iron
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Irons Logo
167 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
