Question about Estate ETW4100SQ Top Load Washer
I have a whirlpool estate ETW4100SQ washer. When I use the Large or Extra Large wash cycle, when the washer starts the rinse cycle the washer keeps filling with water and never stops and never seems to get full. I have to switch back to Small or Medium wash cycle to make the washer finish. What is going on with my washer?
The water is not shutting off when filling, and again in the rinse cycles
Posted on Mar 10, 2011
  • gmaroach Mar 10, 2011
    as in over flowing the machine flooding:(
    Sergeant:
    Champion:
  • 351 Answers
The drain hose is to low the water is syphoning out on the high loads
Posted on Oct 03, 2010
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
Will no longer spin
Hi, I have to ask a couple of questions to pin point this for you. Does the washer agitate?
When the washer is in the spin cycle, Does the motor run at all? The most common problem with the spin cycle is either the lid switch or the coupler. This is why I am asking the questions.
Please let me know so I can assist you.
Vic
Jul 04, 2009 | Estate ETW4100SQ Top Load Washer
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer estate brand ETW4300SQ Model
Sounds like the motor may be bad but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Whirlpool / Kenmore Washing Machine (Direct-Drive) Repair Manual
Appliance Parts Guru
www.RepairaiClinic.com
Feb 11, 2009 | Estate ETW4100SQ Top Load Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate ETW4100SQ Top Load Washer Logo
370 people viewed this question
Top Estate Washing Machines Experts
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
