Question about Seagate ST320005EXA101RK 2 TB USB 20 Hard Drive
This Drive drives me crazy with that click, click, click unstoppable and unbearable clicking noise. The drive continually clicks and is having troubles loading files. Please help. Thanks.
  • 6,831 Answers
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
Clicking noise, won't mount
the controller on the external drive could have gone bad. i would first try removing the hard drive from that external enclosure and use a usb or esata dock and see if itll mount.
Nov 26, 2013 | Fantom Titanium Hard Drive
Clicking noise coming from hard drive
Clicking noise is giving you an indication that your hard drive is about to fail as clicking is one of the symptom of physical hard drive failure. This type of hard drive failure situation needs to be handle on time to rescue yourself from a data loss situation. Also i would suggest you to shut down your system stop doing anything on your system and immediately take expert data recovery assistance if you really want to save your data.
Feb 26, 2013 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
Led error
The clicking noise may indicate a faulty hard drive.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Hard drive powers up and then the light at the front indicating that its on shuts off followed by a clicking noise
hi; if clicking sound is continuous its time to replace your hard drive.
inside your hard disk have failure in one of its heads.
if your computer still read the data inside the HDD backup all the files
into new HDD.
Aug 24, 2011 | Computers & Internet
I have a toshiba satellite m55-s3314 and when I turn it on it stays stuck on the first screen and the laptop makes noises like it stuck
if it's making a clicking noise, like metal-to-metal clicking, then most probably your hard drive is failing. If this is the case, get the hard drive into a USB tray and get all your important data out of it. You'll have to get a new IDE/ATA hard drive for your Toshiba if you want to continue using it.
Jan 19, 2011 | Toshiba Satellite M55-S3314 Laptop
I have an i-rocks 3.5 usb/firewire combo external hard drive that seems to be malfunctioning. When i turn it on, it doesn't boot correctly and my computer doesn't recognize it. It continues to make this...
The clicking isn't a good sign; it means the drive is being repeatedly told to start rotating but it either can't start or come up to speed. There is a problem called 'stiction' meaning that the head(s) are somewhat 'glued' to a disk surface. Haven't heard of this problem in recent years but it still may be possible and not as likely with the extreme shrinkage of head size..
BTW, the actual drive probably has a different name and model number but would have to be removed to see the label.
Sep 05, 2010 | i-rocks External Hard Drive Enclosure -...
Clicking Noise Coming From Engine
oil pump may have to be replace or clean the oil pump strainer must remove oil pan
Apr 12, 2010 | 2001 Dodge Stratus
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
HDD keeps clicking
The clicking noise is the sound of the read/write heads going to the home position. The arm or bracket the heads are mounted on make the noise when they hit up against the equivalent of a *door stop*. This is the drives attempt to reorient itself when it can read something where it expects to find it. As you have guessed its probably a mechanical fault and definitely not repairable.
Jan 07, 2007 | IBM TravelStar 4GN 4.32 GB Hard Drive
Seagate ST320005EXA101RK 2 TB USB 20 Hard Drive Logo
93 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
