Question about GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Dryer works fine, heats and motor turns, but it sounds like I have a shoe in it? Belt appears to be in good condition?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Jan 15, 2011
Drum will not turn unless pushing drum to give helping hand motor turns ok without belt on and the drum spins freely nothing jamming it.It makes a buzzing sound then i turn drum and ok until it stops
If the Drum within a Dryer (I assume that is what your talking about) is not freely splining; then there are two conditions that occur. 1. the drive motor may have over heated and the internal brushes may have bound up the rotational shaft. 2. the drive belt is defective.
Replace either of the two and it should work just fine.
Jan 12, 2018 | Dryers
Kenmore dryer he2
It could be the belt that spins the dryer is slipping, probably needs to be replaced.
Jul 22, 2014 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Frigidaire Gallery Electric Dryer, model GLEQ2170KS.
Can you tell if the dryer is moving air? Is it getting Hot?
if yes, then it sounds like a belt issue. If it is moving air, then the motor is running. If no air, then the motor is NOT running. If this is the case, I would not leave it "Humming" for long. Motor could get pretty hot. Also, there is often a one time over temp switch in the motor. If this gets too hot, this will trigger, killing the motor.
If it seems like a belt issue, look online for instructions for opening the machine up, and check the belt status. Belt could have jumped off a pulley, and just needs to be put back on. Or, something could have failed. You will have to look inside to find out more.
Jul 02, 2012 | Frigidaire GLGQ2170K Dryer
What wrong with dryer when it shuts off after spinning for 30minutes and will not spin at all. dryer was working fine when it stopped drying clothes. It appear to have over heated then shut off...
Check if the motor hums once you turn on the dryer. If you hear a hum then check the starting capacitor if you have a multi-tester try to check if it's still in a good working condition. Replace the capacitor if its already damaged.
Dec 01, 2010 | Kenmore Dryers
Dryer is making a loud rattling sound when it is turned on
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 03, 2010 | Dryers
Dryer drum struggles to turn
hello. i can assist you. there are two possible problems here. If the belt is old and stretched it will cause the issue that you have. The fix is to replace the belt. I would do this first.
The second possible, albeit rarer cause is the motor itself. Once again the only fix is to replace it. begin with replacing the belt. that would be much cheaper. good luck with it.
Oct 25, 2009 | Dryers
Dryer motor turns on but Dryer won't tumble...opened the top and it appears the belt is fine. Are there two motors? One for heat and one to turn the belt?
Your dryer is equipped with one drive motor. If the belt were broke the drum would not turn. The drive portion has nothing to do with the heating circuits of the dryer, other than driving the blower fan assembly to circulate air. More than likely you have a problem in the heating circuitry, or improper voltage at the wall receptacle. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The most common cause of dryer heat related problems is poor, or improperly installed exhaust ventilation. If you haven't inspected your dryer ventilaion ducting any time recently, now might be a good time to do so. If you leave a dryer in a clogged condition, it will overheat to the point of failure. This also creates a potential fire hazard.
The voltage at the wall receptacle should be the first thing to check. Make sure you are reading 220-240VAC across the two hot leads (The LEFT and RIGHT slots). If you are only reading a portion of the voltage, this will cause the same symptoms you describe. The reason: The drive motor only uses half the input voltage to run. The heating circuits require the full 220 service.
If the voltage is bad at the receptacle, verify your breaker are set correctly. You may need an electrician to troubleshoot.
If the voltage is good at the receptacle, UNPLUG the dryer momentarily and remove the cover plate on the back of the dryer where the power cord is installed. Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. If the voltage is good at the terminal, this verifies your power cord and the problem is INTERNAL to the dryer heating circuits. If the voltage is good at the receptacle, but bad at the terminal block, you have a bad power cord.
If you verify the input voltage and power cord are good, the most common fail item in the heating circuit is the thermal cut-out (TCO). This component is mounted on the heater box along with the Hi-Limit Thermostat. These two components work in conjunction to regulate the heating circuit temperature. If one or the other fails, it is recommended you replace BOTH components. They are often sold as a kit. Failure to do so may result in premature failure of any components you replace.
Read through the lnk provided and let me know if you have any questions. I hope this helps you.
Jun 25, 2009 | Whirlpool LEQ9858P Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Dryer heats up but won't turn
Perhaps you have a broken drum belt
May 20, 2008 | Whirlpool LEB6200 Electric Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
GE DBL333EBCC 5.7 cu. ft. Electric Dryer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
