Question about Gigabyte GA-945P-S3 Motherboard
Network adapter device manager show me after instalin driver ,that is missing driver for ethernet controler.I try to conect to my router but is stile geting error message that system dont recognize ethernet adapter.Thx
  • wolakota May 11, 2010
    Dear Mr. Keepwaling,
    Thank you for this solution. I followed your instructions, but got confused when you spoke of extracting to the LAN folder. I did an explorer search and could not file any folder by that name. I did save it to my flash drive and then ran the exe file. So far,no change in my ethernet question mark ! icon.
    Is there any way to check on the ethernet connection'sfunctionality before I head out to get a PCI network card?
    Thanks, The solution was very well thought oout and articulated. It did pertain to my Gigabyte motherboard and the model I had, so it isn't that I took your solution and was trying to solve another motherboard's problem. Thanks for your expertise.
    Wolakota
    President:
  • 2,351 Answers
Hi keepwalking,
There are three revisions for this board. Please click on this link for the correct version number.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=2475
Create a folder on you're desktop & name it Chipset. Listed on the right side of the above page is Drivers. Click on the word Drivers. Next, under Chipset click "Download from". Pick a site to download from & save the download file into the folder you created on you're desktop. The file is compressed. Open the chipset folder & double left click the .exe file. Extract to within the LAN folder. Once finished. Open device manager. Find the yellow ! point for you're LAN controller/driver. Right click on the yellow ! point once & left click update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away. Click the Browse button. . Another window will open. (Browse For Folder). Click the + sign next to My Computer. Find the folder chipset on you're desktop. Open it.
Open the folder, INFUpdate & run the .exe file.
This will re-install the updated chipset drivers for you're Gigabyte board. Make sure you restart before testing you're internet connection. If the update fails to remove the yellow ! point in device manager you're onboard LAN controller may be defective.
It is suggested you call Gigabyte if you're board is still warranted. If it is not warranted buy & add a PCI network card.
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 27, 2008
Dell dimension 1100 DE051 Internet drivers are installed All connected successfully Internet will not work Please help
Check that all drivers are installed and working in device manager as when I reinstalled Windows not all of the drivers installed and I had to do it manually. These drivers were the ones that give you access to the internet. These were network adapters and IDE ATA /ATAPI controllers.
Hope this helps.
Aug 14, 2014 | Computers & Internet
Dell inspiron 530 ethernet controller driver missing
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver will be on the disc supplied by your ISP internet service provider
hope this helps
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.htm
lhope this helps
Apr 02, 2011 | Computers & Internet
Can not conect to the router using "http 192 168 1 1 to set the router up
if you need an ethernet driver or it might be something else
2112_4-91313.htm
check the password make sure its exactly how you provided to your ISP internet service provider make sure the Caps lock is on/off which ever applies to your ISP contract
check your computers settings ie: firewall also he might have a default internet setting
check the leads from the modem/router whether usb,ethernet make sure they are not bad/faulty and have secure connections and try different ports
hope this helps
Mar 17, 2011 | Computers & Internet
DEVICE MANAGER SHOWS NO DRIVER ON MULTIPLE DEVICES MS VERSION 6.1.7600.16385 AND RED ERROR CIRCLE ON I/O RANGE 1100-111F. I'VE TRIED TO UPDATE ON LINE AND SYSTEM BUT GET MSSAGE (THE BEST SOFTWARE IS...
If your device manager indicates a good network adapter, wireless and/or Ethernet, go to the Dell website, select support, drivers and download, and enter your service tag number. It will direct you to all the drivers you need to get you computer operational again. If the device manager indicates missing network adapter drivers, you will need a flash drive, a computer that can connect to the Internet, and transfer the network adapter driver to this computer.
Feb 11, 2011 | Dell Inspiron 1545 Notebook
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
No conection to internet by local network
hi! there,
if you have *********** board installer,install and the wizard will find your ethernet driver if this buit in ethernet,but if you have an external pci enthernet device go to device manager,left click and click the properties of fast ethernet pci device,try to update your driver on website.device maneger can find on control panel under
system,click hardware,click network adapter,click properties and click on drivers and update your driver.have a nice day.
Apr 15, 2009 | Computers & Internet
Network Adapter/Ethernet Controller
Nothing wrong with having two network adapters installed on your computer. If you have this DWA-552 wireless adapter installed as well as an onboard NIC, the correct thing to do is have both drivers installed so you see them both in your Control Panel->Network Connections window.
If you really want the onboard nic to go away, go into device manager and disable it - not uninstall it.
Mar 08, 2009 | Computers & Internet
Compaq presario broadcom adapter not showing
Hi!
I will assume that your broadcom adapter is not showing up under Device Manager > Network Adapters. It will happen if the driver is not properly installed.
Look for "Other Devices" under Device Manager. Usually, it will show as Network Controller or Ethernet Controller. Right click that and select update driver. Make sure that you have the driver or file for that adapter. Once the driver is properly installed, it will be under Network Adapter with the correct name.
I hope that helps.
Good luck and have a nice day!
Nov 27, 2008 | HP Computers & Internet
Ethernet controller driver
What is the model number and brand of your PCMCIA Card ?
Dec 11, 2007 | Compaq Network adapter
Gigabyte GA-945P-S3 Motherboard Logo
170 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
