Question about Homelite Garden
I have a Homelite Trimlite model UT20706 trimmer. I don't know how to put a new string on. It uses a single string that is spooled for two "wips"
  • 1,041 Answers
Here is a link to one of my Tips: www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
If you need more help, let me know.
Good Luck!
Jim
Posted on Oct 04, 2010
Need to change the weedeater line.
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Sep 29, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Installing new line on my string grass trimmer
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Load new line onto the mighty vt26 17" curved trimmer
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
Jim
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Need part number s for the entire head assembly of the Homelite Trimlite UT20721" or manual and diagram
Hello daniel_s_kmi:
If I Understand you, you are Looking for the Part Number for the Complete String Head.
If this is Correct, then the Part Number is DA3001A.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.homelite.com/service_support and Select Order Parts. Now Select "Click to Launch Homelite Catalog". Now Enter the Model Numbers (UT-20721) and Click Search. Now Double Click on the Model in the Results Area. Now you can View the Breakdowns for this Unit. Select the "Shaft-Spool and String-Grass Deflector" File. The Complete String Head is # 17 in the Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
311 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
