Question about Whirlpool LGV4634JQ Gas Dryer
I have no interior heat in the drum. I hear what sounds like pebbles inside the dryer, but they stop rattling after about 10 seconds. After about 30-45 seconds, they start again and stop. I have checked both inside and outside vents and the unit is level. I have heat in the laundry room, and a damp smell, but no heat inside. Ideas??
    Sergeant:
    Champion:
  • 351 Answers
Blower wheel is loose
Posted on Oct 03, 2010
Maytag dryer stops running after 10-15 seconds.
Check the exhaust vent in the dryer and the one going outside, sounds like it's plugged. If it's plugged the dryer will get hot real quick and shut off so it doesn't catch fire...
Dec 11, 2014 | Maytag Dryers
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
Whirlpool refrigerator model ED25PQ. Interior warm
possibly the relay on compressor is bad. the relay will need to be removed. shake it, if it rattles and or particles fall out of it, it is bad.
Jan 08, 2010 | Refrigerators
Dryer makes squeaking, rattling noise whe starting. Goes away after a couple of minutes.
sounds like your bogie wheels may be starting to ware out they are bottom left and right drum inside front panel if worn they take 10 mins to replace
Dec 18, 2009 | LG DLE2532W Electric Dryer
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
1997 Acura 1.6EL rattle underneath front end
you could have a loose heat sheald or a broken catilitic converter you should take it to a shop and have it looked at tobe safe
Jul 13, 2009 | 1997 Acura CL
Whirlpool LGV4634JQ Gas Dryer Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
