Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I've replaced the ignition module on my Poulan Pro 4218AVHD but it's not starting....does anyone know what the gap size is for this part? I checked the spark plug and it's getting spark but I don't know if it's getting enough.
  • 3,740 Answers
The spark should be blue in color not orange or white. A bluish ornage is ok. The easiest was to set the gap is to tear off the front and back of a match book cover tear it in half and place the 2 pieces between the module and the flywheel losen the module and let it slide against the match book cover. Tighten the mounting screws and then turn the flywheel to remove the match book cover. <- (Been doing this for 40 years!)
I suspect your problem may be fuel / carb related vs ignition.
However.... a bad spark plug will spark when removed and you have grounded the electrode end to the engine but will NOT work when you install it. Make sure you change the plug. (FYI I have seen new Champion mini plugs fail right out of the box.) I have had as many as 3 in a single NEW box of plugs fail.
Just for grins try adding a splash of gas into the spark plug hole or carb throat before you try and start it. If you get a momentary start you have carb / fuel supply problems.
If you discover you have carb / fuel problems just repsond and we can proceed with getting you going again. I will help you.
Thanks for Choosing FixYa
Kelly
Posted on Oct 03, 2010
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
Am replacing ignition module , What is the gap setting ? Poulan mode; BVM200VS
Use a clean and dry business card or other card stock paper to set the gap. That is almost perfect for the .006" setting.
Aug 24, 2010 | Poulan Pro Gas BlowerVacuum ()
No spark form high tention wire chain saw will not start
Try a fresh plug gapped at 0.020". If no help, remove the cover from the flywheel side of the engine so that the flywheel and ignition module are exposed. Remove the ignition switch wire from the module and try for spark again. If nothing, then check the gap between the flywheel magnets and the module poles with a thin business card--insert the card into the gap and allow the module to snap to the magnets when the screws are loosened and then tightened. Rotate the flywheel somewhat to work out the card. Recheck for spark again--if still nothing, replace the ignition module using the same procedure as above for installation (don't forget the ignition switch wire). Hope this helps!
Jul 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Air gap setting
I assume you are speaking of the ignition module pole gap to the flywheel. Rotate the flywheel magnets under the ignition module poles, and use a thin business card for a gauge. With the card in place, loosen the module screws and allow it to contact the magnets, then re-tighten the screws. Rotate the flywheel to remove the card, then turn the flywheel one full turn to make sure the gap does not close up at any point. Don't forget the ignition switch wire. Hope this helps!
Jul 06, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My poulan predator dies after it gets hot, about min., then will not restart until it cools off.
Remove the spark plug and check for snappy, blue spark when the saw quits. If nothing, try a new plug. If still nothing, remove the flywheel cover to expose the ignition module. Remove the ignition switch wire from the module and try for spark again. If still nothing, replace the ignition module. Use a thin business card for a core gap gauge with the flywheel magnets under the module--insert the card into the gap space and allow the module to contact the card and magnets. Tighten the module screws, then rotate the flywheel to release the card. Rotate the flywheel one complete turn to make sure the gap doesn't close up further. If you got good spark in the first test, then place some fuel mix in the plug hole and try for start--it should pop several times. If it does, then concentrate on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Check the fuel tank vent in the cap for plugging. Hope some of this helps!
Jun 29, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 295 model chainsaw/ won't start, no spark
Start first with a fresh spark plug set at 0.020" gap. Make sure ignition switch is on. If still nothing, remove the cover from the flywheel. Set the ignition module gap by using a thin business card between the module poles and the flywheel magnets. Loosen the mounting screws, let the module contact the magnets, and re-tighten the screws. Turn the flywheel to remove the card, then rotate the flywheel on full turn checking that the gap doesn't close-up any further. Check for spark again--if still nothing, remove the ignition switch wire from the ignition module. Check for spark--if spark now occurs, check the condition of the ignition switch or the connecting wire may be grounding out somewhere in between. If still nothing, replace the ignition module. Hope this helps!
Jun 10, 2010 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan 2050 is there a setting for the the spark plug?
Use 0.020" for the plug gap. If the spark is weak looking, check the ignition module to flywheel magnets gap using a thin business card for a gauge--turn the flywheel magnets under the module, insert the gauge, loosen the module screws to allow the module to clamp to the magnets, the re-tighten the screws. Rotate the flywheel to remove the gauge, then make one complete revolution of the wheel while checking the gap--it should not close up any more than originally set. Recheck for blue, snappy spark. Hope this helps!
May 27, 2010 | Poulan Pro Chain Saw 46cc 20"
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Gas chainsaw has no strong spark and wont start
the air gap should be .012", the gap you have it set at is to small.reset the gap and try it again.......hope this helps,let me know........
Jun 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
634 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
