Question about Keurig Special Edition B60 Coffee Maker
I just bought my Keurig B60 new from a neighbor who bought it and used it once. She didn't like it becuase it didn't fill up her cup. I've had a single cup Keurig for years, but it finally stopped working. I bought the new one from my neighbor with no reservations. Well, I just made my first cup of coffee and to my dismay, it only put out 3-4 oz. of coffee in my cup. How can I remedy this problem?
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Posted on Oct 07, 2010
I have de-scaled and water pumps fine. Once I put the K-Cup in, the Keurig will not brew. I've cleaned the nozzle and ran the machine without a K-cup in and all is well. Once I put the K-Cup in no...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 14, 2011 | Keurig B60 Coffee Maker
Partial cup fills some water returns to reservoir i've already cleaned the small holes and descaled
heatman101
Jul 13, 2011 | Keurig B60 Coffee Maker
My keurig b60 water flows back into resevior while brewing cup never fills.
heatman101
May 31, 2011 | Keurig B60 Coffee Maker
I have the Keurig B60 I love the coffee it makes, the only problem is after you make a cup of coffee and the water is filling up again to get ready for the next cup, it is so loud, I know this is not...
If you bought yours after your son it is very possible that you have a newer version with a stronger pump...this pump is very noisy...they did this to try to eliminate some priming problems...
heatman101
Apr 01, 2011 | Keurig B60 Coffee Maker
My Keurig B60 is inconsistant in filling the cup. When I push the large cup to start brewing, it sometimes gives me 1/4 cup, 3/4 cup or a full cup.
heatman101
Mar 24, 2011 | Keurig B60 Coffee Maker
My keurig b60 looses its prime do you know how to fix it?
The easiest way to to just leave the tank on once you get it primed and then fill it with a pichter...
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Mar 06, 2011 | Keurig Special Edition B60 Coffee Maker
Keurig B60. Brand New used maybe 4 Kcups. Now it won't fill a full cup setting. Maybe 1/4 cup. You reset, get a little more to run through. At this rate going to be a long time for a full cup. took...
if water does go thru it...try white vinagar/water mixture about 1/2 cup vinagar to full tank water..
run cycles until empty...NO Kcups..then run full tank of clean water.....
Dec 18, 2010 | Keurig B60 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
249 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
