Question about Crosley CDE6000 Electric Dryer
Crosley cde22bgv, gets warm but won't blow right. Takes about 4 hours to dry a load of clothes.
    Sergeant:
    Champion:
  • 351 Answers
Check make sure the vent is not stopped up and that the blower wheel is not lose
Posted on Oct 03, 2010
Only gets warm and takes hours to dry
Could be a defective heating element.
Mar 02, 2015 | Dryers
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Dryer won't dry clothes
How to check the timer:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 26, 2012 | Whirlpool Dryers
I have a model # CDE20P8A crosley clothes dryer that will not start. It has power to the dryer, but the interior light or motor will not work. Is there an internal fuse that I should check or replace?
Yes. It takes an LA-1053 fuse kit. Most of these dryers take way too long to dry the clothes, then the fuse blows because it over heats. The problem being the blower wheel. The fuse itself is attached to the side of the heater and is held there by a clip that is held in place by the long screw that hold the element. Unplug it and take it outside so you can sit it on a table to work on it.
To get inside release the clips
It won't do any good to replace the fuse if ya don't check the blower wheel.
They strip out and get loose on the motor shaft.
Aug 01, 2011 | Crosley Dryers
This dryer is a gas model. Drying a load of clothes takes several hours. The exhaust vent has warm air blowing through, but it isnt' hot.
Most often, this is caused by obstructions in the vent pipe. Check to see if it needs to be cleaned-out. The blockage is usually closest to the dryer.
Jan 20, 2011 | Kitchen Ranges
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Dryer is not drying clothes very well
check your wall vent,if it is clogged it will not dry right-mike
Jan 24, 2010 | General Electric DHDSR46EGWW Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Clothes take a very long time to dry
You need to remove the front panel and clean out the lint and replace that bad blower wheelaa0396a.jpg
Feb 21, 2009 | Crosley CDE6000 Electric Dryer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Crosley CDE6000 Electric Dryer Logo
44 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
