Question about Craftsman Electrical Supplies
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
  • Anonymous Mar 30, 2014
    I have a Craftsman 5600 watt Generator and the Outlets are not working, we swap the outlets and still nothing. What could be the problem with the outlets?
    My Craftsman 5600 watt Generator Outlets will not work. When I first bought it , they worked.. by the time I was ready to use it..I couldn't get the outlets to work..I swap out the outlets and still not working.
  • 5,568 Answers
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Posted on Oct 03, 2010
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
White smoke
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Apr 01, 2014 | Craftsman 5600 watt Generator
Duro max xp4400 generatol is not producing electricity
Check power going to the breaker. Check the brush conditions and the trace condition.
May 14, 2013 | DuroMax RV Grade 4400 Watt 7.0 Hp Gas...
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
My craftsman 5700 generator has gas inthe oil...why?
your float is stuck and wont shut of the needle and seat so it floods make sure you shut fuel of when not running and check your needle and seat and see if it shuts of the fuel from the tank
Oct 29, 2012 | Craftsman 5600 watt Generator
Generator keeps stopping
ck the oil if its low it will not stay ruunning
Oct 27, 2012 | Craftsman 5600 watt Generator
Have inherited a homelite generator- LR5000T what grade of oil does it take. Also, does it support 220 volt equipment? Equipment draws less than 15 Amps.
Yes, this generator supports 220 volt. The grade of oil advertised for this generator is 10W30, 4-cycle.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | Homelite Garden
The unit starts and runs but does not put out any electric . it is a craftsman 5600.is there a fuse or reley
Most generators do not have any fuse in them, but they have "diodes" and "capasitors". When any of these go bad there will be on output from the generator even if it is running.You will need to open up generator to locate these components.
May 09, 2010 | Electrical Supplies
Electrical Supplies Logo
350 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
