Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Line cutter blade is missing. Where can I get the part? I can't find it on the B&D website.
    President:
  • Black & Decker Master
  • 1,545 Answers
Posted on Oct 03, 2010
Testimonial: "Thanks. I used your info and ordered what I needed. Bob"
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Bobbin thread not cutting
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
May 13, 2014 | Husqvarna Designer I
Auto retract slice cutter slider that moves blade out will not latch. I have to hold it in place with my thumb and so can't make any cuts. Am I missing something?
If I am reading this correctly, your answer may be that the cutter is designed that way for safety. "Auto-retracting". You find it in some utility knives that often store employees are required to carry so they won't "hurt themselves". Annoying, really. Try buying another cutter that is not an "auto retract"-- or get used to using your thumb for the purpose of holding the slide so the blade stays exposed.
Mar 23, 2014 | Slice Ceramic Safety Cutter
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
Need to find out haw to adjust cutter head and blades.
I called Jet and they e-mailed me a pdf file with the older manual. There is a toll free number on their website.
Jan 26, 2009 | Delta Jointer Blades 6 Inch Fits , Jet...
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
309 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
