Question about Toshiba Satellite M35X-S161 Notebook
I need to replace hard drive. On start up it says impending hard drive failure. Can I use a SATA or must it be an IDE. How big of a drive can I use? 250g? How difficult or easy is it to change?
  • 3 Answers
I went through this problem 2 years ago. At the time I could not find an adapter for a SATA nor a larger HD without for less than a new inexpensive laptop. You need to purchase an IDE USB adapter to make your HD an external drive and recover your data. I found one for $12.00. I still use it with my old drive as for backup. Next format the old drive, if you are reusing it and install the operating system. I was able to find most of the drivers at Toshiba web site. I also used the CD's that came with the laptop for the video, internet adopter and modem drivers.
Good luck.
Posted on Oct 27, 2010
Sata pata ide hard
A sata drive doesn't need jumpers. The jumpers were only required when 2 drives used the same cable.
Nov 28, 2013 | Dell Dimension 3000 PC Desktop
Replace hard drive
The eMachine T3995 hard drive was originally an IDE 250GB drive. These drives are obsolete and hard to find.
I suggest using the following Generic IDE to SATA device on Amazon for about 7 dollars and then replacing the IDE drive with the SATA drive of your choice such as the 320GB Western Digital Blue listed on Amazon at about 25 dollars. Both IDE and SATA drives mount the same way.
Feb 08, 2013 | eMachines T3995 Power Supply Part Number...
Strike A1 key to start PC
is the hard drive ide or sata, enter bios and disable all hard drives in the configuration with the exception of the primary. you could also try to change the sata configuration from ahci to the other option.. i can't remember what it is off hand.
May 05, 2012 | Computers & Internet
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
When my computer tries to start/boot it stops and gives these messages. two that caught my eye are: media test failure check cable and operating system not found. it won't completely boot and turn on. what...
Are you using laptop or pc in both cases the message indicates problem with your Hard drive please check in the bios is the hard disk available if yes please check is it set to proper mode like if your hard drive was insttaled with raid mode it should be in raid if its insattled in a ide mode should be set to ide
Thanks
Apr 18, 2010 | Gateway MX6955 Notebook
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Using a Sata Drive with an IDE cable
Depending on how old your system is, even though your current drive is IDE, there might still be SATA support on the motherboard. Look in your manual and find out if it has any SATA connectors. If not, you need to continue using IDE unless you want to purchase a PCI card with SATA connectors on it.
Apr 28, 2008 | Computers & Internet
Hard disk problem
If the sound is a new sound, I'd suggest getting a new HDD. It could be a sign of impending failure. Hard drives cannot be repaired.
Cheers,
Flyback
Apr 23, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Can i replace the default hard drive with any brand hard drive?
Well the replacement drive should be the same interface. i.e. if its an IDE drive then you'll need an IDE drive if its a SATA drive you'll need a SATA drive! regards, babb
May 07, 2007 | LaCie (300773) 1638.4 GB Hard Drive
Toshiba Satellite M35X-S161 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
