Question about Dryers
I think my LG DLE 2516w dryer got too hot. I have read of a reset switch that may need to be flipped. Could anyone tell me how to access the switch?
  • 1 more comment
  • john_elet Oct 03, 2010
    I have read that if this particular dryer gets too hot because of lack of circulation, it can flip a "switch" that will need to be reset. Can you tell me if this model has this switch, and how to get to it? I think that I can reset the switch myself, but if that is not the case I will need to know how to test the sensor or the thermostat.
    I have tried the things suggested. Would you be able to tell me if my model of dryer has this switch that I have read about on the Internet? If so, could you advise me of how to access it?
  • john_elet Oct 04, 2010
    President:
  • 2,468 Answers
There is no actual reset switch in these,but the High-Limit thermostat has an auto reset if it becomes too hot and this is your problem,its not opening and the element cant cycle on and off to keep the correct temp,its accessible through the front panel below the drum area on the heater element case,you need to first remove the top cover to remove the front control panel and front door panel
Posted on Oct 04, 2010
  • 4,323 Answers
Hi
Dryer getting too hot means failure of temperature sensor or thermostat. You'll need to check and replace these. Try and pull out the cable of the dryer or flip the circuit breaker (if any connected seprately for dryer of the main circuit breaker). Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 03, 2010
LG TROMM DLE 3733W dryer Sometimes it won't heat and try the clothes and sometimes it will. I hear the high temp switch kick off when it doesn't work.
You might have excessive lint build up in the air flow inlet. Then excessive heat trips the thermostat limit switch. The thermostat limit switch could be defective too.
Oct 19, 2015 | Dryers
DLE 5977B ELECTRIC DRYER wont start
On the exhaust is a limit that trips with bad air flow. I think that puppy is resettable:
LG service manuals
Aug 15, 2012 | LG DLE2532W Electric Dryer
Hi need to order parts were can i get them
Hi
Thanks for using FixYa. You can order the parts from any of these two links:
LG DLE 2532W Parts
LG DLE 2532W Parts-2
Please do rate thesolution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | LG DLE2532W Electric Dryer
No heat, and my drum is cracked, too!
Measure the voltage (with a voltmeter) at the two slanted slots in the dryer power plug which should read ~220 volts AC. If at or near zero, there is no power from the breaker pair in the house electrical panel. Go to the panel and push the breaker pair to off, then on. Recheck the dryer socket again. If still zero reading, one or both breakers are bad (assuming that you didn't plug the dryer back in after checking the voltage). If you did, remove the dryer plug, reset the breakers as before, and recheck at the socket once again. If you now have voltage, suspect a short circuit within the dryer--likely the heating element. You will need to remove the drum to access the element area. Make sure that the entire air vent area is open and clean the filter in detergent and hot water. Replace the drum if it is catching on clothes
Aug 19, 2009 | LG DLE2532W Electric Dryer
LG DLE 2516W dryer has internal vibrations. something is rattling or vibrating inside and makes a racket when it is spinning slow or fast. the dryer is level and the leveling feet are all adjusted.
Check and make sure the shipping screws were completely removed.
If they are still in place, even partially, the tub was most likely damaged.
Aug 09, 2009 | LG Dryers
LG DLE 9577
check to make sure that the power legs are correctly installed.  Use an volt meter and measure voltage across neutral and hot.  Hot leads should be on the left and right side and neutral is in the middle.  Hot to neutral should be 120v.  Hot to hot should read 240v.
Feb 06, 2008 | LG DLE9577 Electric Dryer
Dryers Logo
163 people viewed this question
Top Dryers Experts
