Question about MSI K9VGM-V Motherboard
The system doesn't boot, more excatly the PC tries to boot. Just as windows is about to load two short beep's is heard, and the board reboots (System fan slows down in speed and then bios is loaded again) This repeats on and on
    President:
  • 2,571 Answers
Opinions vary depending on your bios make.
It may be a faulty graphics card, bad memory or even bad bios settings, the full lists of errors are here
http://forum-en.msi.com/index.php?topic=86906.0
Posted on Oct 03, 2010
  • 31 Answers
Your computer registry is damaged and windows shuts this down to avoid further damage, the only thing to do is use a recovery disc on start up.
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
T2865 Starts to boot but freezes at diff.stages- no beeps
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot. After reboot your problem should be resolved.
Nov 15, 2011 | Computers & Internet
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I was previously surfing the net using Chrome and I had opened many many tabs.. My laptop (Fujitsu Lifebook S Series - S6420) then hung/hannged and I couldn't do anything so I held down the power button to...
Your beep codes are..
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card .
So looks like a display problem, have you tried any of the recovery/restore options available when you press F8 on boot up
Sep 30, 2010 | Intel S6240 Notebook
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
thnk you.
Nov 29, 2008 | Computers & Internet
MSI K9VGM-V Motherboard Logo
77 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
