Question about Craftsman 24 Hp 48" Deck Yard Tractor
I have a DYT 4000 from 2004. Cutting the lawn today, about half way through something inside the engine popped (sounded like a belt) and the tractor shut off. I tried to restart and the starter was FLYING but seemed to be free. Checked the oil level (might as well, it's out of commission) and noticed white whispy smoke coming from the oil fill area. It had been running for about an hour. Any help is appreciated.
  • 110 Answers
Sounds like an internal engine failure. Take the spark plugs out and stick a screw driver in the the cylinders. Then turn the engine by hand, and see if the pistons move. My guess is one or both won't, but if they do then you'll need to do more testing like a compression test or leak down tests. You may even need a partial tear down to find the problem. Sorry to be the bearer of bad news, but it is possible that it is repairable rather than having to purchase a whole engine.
Posted on Oct 30, 2010
I have a JD LA110 2007 engine runs fine was cutting lawn and it just coasted to a stop and won't move now. I did smell a burnt smell chked belts look ok.
Sounds like you may have a belt that popped loose. While the belts may look intact, they can sometimes jump out of their groove. Check to make sure the drive belt is routed properly, and that it is tight when the clutch/brake pedal is out (in the drive position). If the belt is routed properly, and the belt is not tight in with the pedal in drive, chances are your tension pulley assembly may have broken, or something else is amiss in the drive pulleys. Also make sure to try all the gears.
Sep 16, 2013 | John Deere Garden
I hit a metal pipe with my cub cadet zero turn lawn mower today. Now it smokes under the deck when I engage the blades and it is not cutting the grass. Have I ruined my mower?
You'll need to look under the deck w/ the mower not running and see why the blades aren't turning. Most likely something is bent (maybe blade) and hitting something. The smoke is probably from the belt slipping and getting hot.
Aug 09, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My Husqvarna lawn tractor started smoking terrible about half way through cutting the grass today. Oil dripped out of the muffler. What is that a sign of? Have I blown the engine? I check tires and oil...
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
May 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The blades turn then stop on their own,is there an
Look for your model number under the seat. Sears website is www.searspartsdirect.com. It sounds like a bearing may be wearing out, or a spring on one of the brake arms is not holding the brake arms off the pulleys;
Or an idler pulley is not holding tension on the belt.
There is not adjustment I know of, just replacing worn parts. Hope this helps. Good day.
Apr 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
420 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
