Question about Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy
I cant find other end of high speed enable connector. There is a connector under seat area with yellow tape but I don't know what to plug it in to? Can you help?
2 Suggested Answers
SOURCE: Power Wheels Kawasaki FFX Ninja...has a wire
It is by the stearing column.inside.If you have small hands put them inside and pull on a grey wire.that should be it.Called the help desk and they helped me with this.
Posted on Apr 08, 2009
There are 2 fuel lines and 2 electric plug in connectors attached to
Try soldering it. And electrical tape might work
Feb 25, 2015 | 2004 Ford Escape
Husqvarna kill switch
n my 79 390CR the white and yellow wires are taped off and not used.
The black and blue wire connectors plug onto the coil as you know, but my blue wire connector has a second blue wire in it.
The second blue wire goes to my kill button.
And yes, the green wire on a Honda switch would go to ground.
I believe the yellow wire is for lighting. Sorry I don't know what the white wire is for.
Hope this helps,
Jul 28, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
My 98 Toyota corolla's headlights on low or high
hello, it could be ground connection issue, carefully check under the dash at the left side there is a ground bus point, it's a the end of a insulated harness which may be taped to the other harness, all white black wires terminate at the end plug connector, there is a cap on the end, it's a white connector with a bunch of wires going into it, all white/black, remove the cap there may be some corrosion inside, all these wires must be grounded if they are not then make new ground connections to the body. a couple of the wires are grounded and the others get ground from them, however you do it doesn't matter as long as all are grounded. Also take a look at the fuse box inside there may be some wires that look overheated which is a sure sign of bad grounds in the DRL and lighting system,
Jul 18, 2017 | 1998 Toyota Corolla
I need to know what the six wires that are on one plugin goes to by the color of each seperate wire for the drivers side electric seat. The Colors are: Black, Red & Black, Yellow & Green, Yellow...
That connector is for the lumbar support in the seat. The wires are as follows:
Black - Ground, ends at left side under the dash.
Red and Black - Power to circuit fromk fusible link
Yellow and Green - Lumbar support, Push out
Red and Yellow - Lumbar support, Release in
Yellow and Blue - Side lumbar support, Spread out
Yellow, Should be Yellow and White- Side lumbar support, Close in
Hope this helps. Good Luck!
Apr 29, 2011 | 1994 Mitsubishi 3000GT
How do i put it in high gear?
go to battery compartment, youll see another plug up front by the front of the seat, plug it on and presto! use the pedal along with the throttle and youve got high gear..simple as that.
Apr 10, 2010 | Fisher Price Power Wheels Kawasaki KFX...
Have an extra connector and dont know where it plugs in at
purple and yellow should be crank sensor and it plugs into the coil pack on the drivers side closest to the firewall
Dec 14, 2009 | 2001 Pontiac Montana
2001 PT Cruiser Limited Ed. Airbag light keeps coming on and off and chimes every time it does. Is there any way to turn it off for now, its driving me bonkers?
There may be some reasons of coming the airbag light on your PT Cruiser. Some connectors could be loose under seats or sensor of steering wheel could fail. However it is really rear. Your problem is probably caused by common problem in PT Cruisers - by broken wire on driver's seat.
Before you start doing anything disconnect a car battery. After 15 minutes remove a plastic panel from the seat (the one you can see when you open your door). Than you will see a wire in plastic cover. It connects an airbag in your seat and yellow connector under the seat. The wire breaks near to the second plastic T-shaped part (looking from the top of the seat backrest). It is located where is a pooling line and rising seat connector wire - somewhere in the center of lenght of the seat. Put the seat backrest to the vertical position, push up the black plastic cube of the line to remove it and have some room to repair the wire, cut a cloth tape. You should have ***** white and red wires. Inspect the wire about 1,5 inch from the center of the place where was the center of the T-shaped plastic keeper. The wire outside will be looking as new, but coper lines inside used to be broken. Strech slightly one by one of the 2 wires. When you find the break just cut the plastic cover in that place, remove 0,25 inch of the cover from each of cut end of wire and twist the ends or put extra 2 inch insert of the same wire. Wrap the coper wires in insulating tape neatly and tape all of the wires together with the T-shaped plastic keeper. Put on place the line udjusting a backrest of the seat, the keeper and plastic cover of the seat. Connect a battery and check it.
If you are not sure where is the place whre the wire could be broken, it is exactly 30 centimetres from the connector of the airbag. TomasS
Jun 14, 2009 | 2001 Chrysler PT Cruiser
Air Bag Light for passenger/Resistance high
passenger air bag resistance high caused by loose connection at psab connector. remove connector and twist pins slightly very slightly. connector is under pass seat and is yellow.
Feb 04, 2009 | 2001 Hyundai Sonata
I repair my Equinox 2007 under seat after that the passenger airbag is shown OFF ?? I havnt seen any problem before under seat repairing .
HIYA!
All Equinoxes has yellow coloured wire harness to identify this as a air-bag system.
This yellow coloured wire 'system network' has connections in some areas...one is located at the front passenger's floor area close to the door (right-side corner area, just remove screw or clip and plastic trim part to gain access to see yellow wire there-it has socket plug connected with red clip-string to secure it) and another yellow wire is found between the front seats-you need to remove armrest, center console area and possible remove the front passenger seat to see yellow wire connect to black device underneath carpet in the middle.
Check to ensure the yellow wire sockets are plugged in properly, and not accidently cut or pulled off during your underseat repair.
In case your Equinox has roof side air-bag option, the yellow wire/sensor are located below the front seatbelt device inside the lower pillar frame area. (it's between the doors)
Hope this help you solve your repair task.
Jan 11, 2009 | 2005 Chevrolet Equinox
Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
83 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Bruce Mommaerts
Bruce Mommaerts
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
