Question about Coleman Heating & Cooling
Weedeating around unit, hit two small wires going into unit they were stripped and sparked, now unit does not work. If you push coil in unit will run
  • 1,420 Answers
Replace wires and protect them. Replace fuse in air handler unit.
Posted on May 27, 2008
Scooter has compression new spark plug new gas and fully charged battery but still wont start
ok first you sed you took spark plug out an checked for spark so the next thing is to look for coil cause some times it can get some rust or many other things but take flywill off an take a small strip pf fine sand paper dut works the best is a womans fingernail file strip off the fine side of one an run it accurse the top of the coil it should have a small tip on it kinda looks like a battery the positive has that little round tip but do not file it to much just so you can see clean meatl then leave the cap that covers the flywill off just so you wont have to go through takeing it off again seconed thing if that dosent work check your spark plug wire oh an when you take the flywill off sand the inside if it an the outer as well hope I helped yeah an if you would like you can call me at 1 417 818 4091
Apr 09, 2015 | GAS Motorcycles
How can I test my ignition coil pack on a 2002 Mercedes benz c240
put a spark plug in each socket you want to test and run a ground wire from the spark plug to the engine ground. then try starting the car to see it they spark. when I tested my 4 cylinder coil pack they were all together. I had 4 plugs sticking out and used an old stripped wire and wrapped around each base of the spark plug in series and then tied it to a ground point. worked great
Mar 12, 2015 | Mercedes-Benz 240 Cars & Trucks
Broken spark plug wire eater weedeater
If the wire runs all the way to the inside of the coil pack, then you will have to replace the whole coil unit.
George
Oct 24, 2013 | Craftsman 25cc Gas Line Trimmer
Gilera cougar no spark
Not knowing about Gilera but Some general suggestions for ignition problems control if applicable could be: a bobin(coil) sparkplug plugconnector control the gap between flywheel and ignition coil, contact points, contact breaker to mass can have a problem or even a cable,a rotor under distributor hood. or ignition not on time,
If ordering for an engine an ignition coil don't forget always to give up the serialmotor number and year of build to the seller because of marketing technical modifications can be made in the same production year of different ignition coils or flywheels and other.
Sep 01, 2017 | Motorcycles
91 chevy 4.3, put on new coil and icmodule but still no spark, what do i need to check
Hi there:
Refer to the wiring diagram, click here. First of all, you should have battery voltage at the pink wire to the coil with key on start or run. The pink wire coming from the ignition switch, not the pink wire from coil to distributor, although you may have voltage there as well. Second, the white wire for the tach you should be checking with a 12 volt test light while cranking. That should flicker if the primary circuit is ok.Quite possibly the other white wire may flicker also, according to the diagram.
Anyhow, how are you checking for spark and are you checking right at the coil? If so, swap a small spark plug wire for the coil wire and check again for spark at the end of the wire.
Make a test plug. You can make a test plug with a new spark plug and some wire, a mini hose clamp and an alligator clip. First open the spark plug gap to around 0.075" and strip both ends of a 16 gauge wire about 4 foot in length. Attach the mini hose clamp around the threads of the spark plug cause that is a ground and secure it with the mini hose clamp with the bare wire end in between to make a good connection. Next, take the other end of wire and secure to an alligator clip.
Now, you have a test plug. Remove any spark plug boot you want and insert your test plug onto the spark plug wire end you just pulled off and ground the alligator clip. Lay the spark plug in some shade somewhere under that hood and then crank the engine and look for spark. It should crackle with sound and should be blue but red is ok, orange is a little weak. If it can jump that 0.075" gap you should have no problem igniting an engine.
You can also use that to check coils on some vehicles.
Hope this helps.
Mar 26, 2012 | Chevrolet Cars & Trucks
My weedeater has no spark at all
If there is no spark then I would suggest checking out the plug wire for cracks or breaks If there is none present then the ignition coil could be finished Take it off take it into your small engines dealer and get him to test it.
Dec 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
No spark on sr230...got suggested new plug ngk...unit was hardly ever used.
The best test for an ignition coil is removing the wire(s) going to the kill switch at the coil. Most small engines will run with the kill circuit open & stop when you ground it. If you disconnect the kill wire & you have no spark, than it's a coil.. If you do have spark, check the switch & kill wire for a short
Sep 22, 2010 | Echo Garden
Hello Does anyone know the ohm readings out of
The woozy spark is generally associated with plug type/condition, the plug cap and the ability of the coil to provide it. You can go down a very expensive path testing and replacing electrical components. The HT lead exiting from the coil is totally sealed up and is not the problem in general. Coils usually breakdown in the internal windings to give wavering spark with different input/loads. Coils can be sourced from as little as $15 from a salvage yard or around $45 new off ebay. First though, get a new plug cap and a couple of clean plugs of different heat ranges and try different gaps. If no change then your coil is next. Components from here generally double/triple in price each step from Reg/Rectifier, CDI Unit, Stator Coils etc. Ohms readings will generally be viable then. The link below has many manuals free to download if you are needing any technical figures for resistance etc. Goodluck and cheers
http://www.yamahaownershandbook.com.au/?r=0
Aug 15, 2010 | 2003 Yamaha YZ 250
I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Aug 10, 2009 | Troy-Bilt Garden
My 2001 polaris sportsman 90 is having problems staying running. if you push the starter it will stay running for about 5 seconds then stops! we have tryed adjusting the carburetor and air fuel mixture...
Had the same problem with my 2001 sportsman 90. Weak spark, sometimes no spark, would only run for a few seconds, ect. I found a partially burnt ground wire coming off of the coil. the coil is just above the carb mounted on the frame. Mine was the small black wire on top of the coil and it fixed the five second stalling problem immediately.
Mar 19, 2009 | Polaris ATV
Heating & Cooling Logo
22 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
