Question about Cuisinart CBK-200 Bread Maker
While the dough is kneading the pan keeps poping up and the padel stops turning.
    Genius:
  • Cuisinart Master
  • 1,280 Answers
Are there metal clips on the sides of your cook chamber at the top? If yes, you need to push the pan down until the pan kind of "clicks" under them. Then you know your pan is seated properly. Please let me know if this works.
Posted on Oct 20, 2010
Kneading Paddle
All bread machines have a final "punch down" of the dough that lasts a few seconds before the final rise stage. When "punch down" is over that is when you can remove the dough ball, remove the paddle, set it aside and place the dough ball back in the pan. It usually helps to have your hands dusted with a little bit of flour.
Apr 21, 2013 | Morphy Richards Kitchen Appliances -...
My paddle keeps coming off when the dough is mixing. What's up with that?
Your paddle is probably worn out and has too much play in it. Some play is necessary to get it off for cleaning but it shouldn't be so loose it is coming off during kneading.
Nov 14, 2010 | Breadman TR444 Bread Maker
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
Help - the stirrer keeps sticking, the motor strains to turn it round but it won't go when the dough is in, its too heavy. The last loaf I made I had to take the dough out of the machine and kneed it...
Take the bread pan out of the machine and run a kneading cycle. See if the motor is straining. If it is it could be a belt or the motor itself. If the motor runs nice and smooth and you can see the motor shaft spinning effortlessly, then it's the bread pan itself. See if you can spin the paddle easily when it is out of the machine. If not then it is the sealed bearing in the bread pan that is starting to fail and it's time for a new bread pan. Hank
Dec 13, 2009 | Kitchen Appliances - Others
I have the 5890 Sunbeam breadmaker, I love it except for the kneading blade bakes right in the bread, how can you give a loaf away with that in it?
You can take the paddle out of the bread pan after the last kneading cycle and before final rise. Do this rather quickly if you don't have a pause feature so you don't lose any rising time.
Take the bread pan out of the machine, put dough in a bowl, remove paddle, put dough back in pan, put pan back in machine.
Some people suggested to spray a small squirt of olive oil on the shaft to prevent sticking.
Hank
Aug 29, 2009 | Kitchen Appliances - Others
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Bread pan is being pushed out of the maker when stirring
thats great . the paddles are allways the problem . on my breadmaker about every 6 months i take the shafts out clean and oil them , it keeps the belts from breaking and the pan from poping out . good luck .... if this answer helped please rate 3 or 4 stars . this high rateing will help keep me in the paid answer department . thanks
Apr 06, 2009 | Kitchen Appliances - Others
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Dec 05, 2008 | Sunbeam 5891 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
116 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
