Question about B&K AVR-507 Receiver
How do i do a hard reset on my B&K AVR 507? - B&K AVR-507 Receiver
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
B&K AVR 507 REMOTE CODES
yes you can use universal remote
May 21, 2012 | B&K AVR-307 Receiver
Hello. I have the AVR507 B & K reciever and i just cant get the sound quality out of it like other recievers. Could you please tell me how to get to the treble and bass. I just cant find it on this...
this is an older model and i don't remember there being any controls for that type of thing, a quick look at the manual would confirm this.
Mar 22, 2011 | B&K AVR-507 Receiver
CP CAM PASA ( CPD 507 ) -16 channel MPEG-4 we need the operating manual. 1)Howto reccord in the D Drive of my system of the previous night recorded pictures from the CCTV 2) When i pressed PAUSE, it...
how to reset the CP CAM PASA CPD-507 DVR & also we have forgot the password for the client pc software how to regain the password 0r how to reset the password?
Dec 08, 2010 | Office Equipment & Supplies
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
My b&K avr 507, 5yrs old has just had its R front channel speaker
loose connections. tap on the unit to see if it sputters back on.cant be shorted parts otherwise ther would be no sound at all.and ther is no seperate fuse for each channel.hence it is loose connections on the affected channel.
Feb 17, 2010 | Audio Players & Recorders
KENWOOD VR-507 RECIEVER
No, take the battery out and bring it to an auto part store and they can test it.
Jun 18, 2008 | Kenwood VR-507 Receiver
Error code 507
Basically this means that there is an error with your BB operating system or software, you will need to reload you app's though apploader through your desktop manager.
Pulling the battery out while the device is on is worth a try before you reload the os, this is called a hard reset and fixes 80% of BB issues.
Jun 02, 2008 | RIM BlackBerry Pearl 8100
Does not decode Dolby Digital 5.1 from my cable box
If you have an HDMI cable plugged into the cable box it may only output 2.0 on the digital audio output. Set the HDMI audio to off or 2.0 and then set the cable digital out to Dolby.
Sep 01, 2007 | B&K AVR-507 Receiver
B&K AVR-507 Receiver Logo
175 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
