Question about KitchenAid Refrigerators
Ice maker dispenser dose not deliver ice. the ice mixer dose not turn.
    President:
  • 1,891 Answers
Ck the tempr of freezer it has to be 15 deg or colder . for ice mker to work. cleaning the coils and sk the fans could improve the cooling and ck the door seal . all will improbe cooling . hope these hepl mm
Posted on Oct 03, 2010
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
I have just purchased a Samsung 636L Refrigerator and my icemaker doesn't seem to work. Help please.
Hello Roseanna;
My name is Peter. I am a retired field service refrigeration technician.
I require the complete model number to see what you have. The model number is on the wall in the fresh food (refrigerator section)
First, if you have just purchased this unit is it is under warrantee, where a service technician will come to your home at no charge and fix the problem.
I am going to take a guess, having serviced Samsung refrigerators for years, the type icemaker that you have. I believe you may have a ice maker in a small compartment.
Usually a ice maker will start after the temperature is above 40 degrees F. If this is the ice maker I think it is; in the front of the ice maker, on the bottom, there is a small red square button. This is the ice maker cycle button.
Push the cycle button and listen to hear the water fill the icemaker. Hopefully, the installers had just never done this.
Do you have a water dispenser? Is the water dispensing?
If you do not have a water dispenser, then perhaps the installers either did not connect the water line nor turned the water valve to open.
If the ice maker does not cycle, and the water supply is open, chances are you have a bad ice maker.
I have gone on service calls where the unit was delivered one day and I am there the every next day. On these service call I have found bad compressors, bad control boards, and yes - bad ice makers.
Oct 29, 2014 | Refrigerators
Ice Maker is not dispensing ice
Since it is brand new, it should be covered under warranty but check a few things first. To make ice, you need to have the water, a cold freezer, and the ice maker must be turned on. Since you say you have ice then the temp and the water supply sound OK. There is a shut off option on ice makers so you can decide not to make ice as on option. Check that the ice maker is turned ON. Also, there is an automatic shut off if the bin fills up with ice so it does not overflow. On mine, it is a bar that will raise up higher as the ice accumulates and that will shut off the icemaker. Check that. Otherwise call GE for warranty service on the icemaker.
Jan 14, 2014 | GE Stainless Steel French Door...
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice maker maker not calling for water. changed mixer valve (new) still nothing water dispenser works. the icemaker runs it rotation ok still no water coming into tray
the fill line is frozen in the freezer .remove ice maker fill line is located behind maker use a hair drier to thaw.. could be ice maker too it controls the water valve.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
My ice maker wont deliver ice. can you help
Ice maker/ ice dispenser manual HERE
If the ice maker mold is empty try adding some water. Wait. If a batch of ice pops out then water valve replacement is in order. If it fails to pop out a bit of ice then the ice maker is bad. I have more information on a page I created HERE
Jan 18, 2010 | Whirlpool Freezers
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
Ice maker
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
May 11, 2009 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
