Question about Refrigerators
I have 501R model Sub-Zero refrigerator. There is ice formation on inside back panel
    Sergeant:
    Champion:
  • 351 Answers
It is low on gas or coolant need a appliance tec to fix it
Posted on Oct 03, 2010
    President:
  • 1,891 Answers
Ice build up is cused by the falure of the defrost system. . ck the heater and defrost timer . timer is most common . also clean the air coil and ck fan speed up on top. if dirty if could cause longer run times and this also could be causing the problem and the door seals must be in good cond. hope this helps mm
Frost on back wall of SubZero Model 501R. have cleaned coils
You've got a freon leak. Most likely the evaporator coil needs to be changed out. They upgraded the part number. Instead of copper, it's made of aluminum now.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero Refrigerators
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Ice keeps forming inside on the back panel of mysubzero model 550
If the ice is on the back panel especially a block of ice in the middle left part of your panel, then you have a sealed system problem. Check to make sure that your condensor coils above the refer are clean, and if it continues to have an ice block then you have to have a technician come out an do a major repair. This is not something you can do yourself, most subzeros have a 6 to 12 year sealed system warrantee that covers either all of the repair or just parts. This is an expensive repair if it is not warranteed, but when the refers cost 8000 to 10000 new it is usually well worth it. Most often it is the result of a slowly leaking evaporator, though most inexperienced technicians replace the compressor first, so make sure you use an experienced Sub-Zero technician. Good Luck, Appliance Specialits
Nov 12, 2009 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero unit 501R is not staying cold.
you need to get its dial unit changed. if somehow u can fix it urself, then all the best...
Aug 17, 2009 | Now Hear This Classic Absolute Zero Main /...
Sub-Zero 690 Refrig Side Ice Forming on Back Wall
replacing leaking evaporator on Sub Zero Video
Jun 09, 2009 | Sub-Zero 642
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
249 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
