Question about Garden
Re: John Deere LA115 The traction drive belt is very loose. Normally I would replace the belt, but in this case I ha. ve reason to believe replacing the belt will not solve the problem. Actuating the deals does not cause the belt to tighten. WThe belt is a bit worn, but not so worn that it should not work. Any thoughts or suggestions? Thank you! Robert Wood
  • 1 more comment
  • Robert H Wood Oct 04, 2010
    Tried the new belt and it did not rectify the problem. Any suggestions as where to go frm here are welcome.
    Thanks!
    Robert
    Would be grateful to have your reply.
    Thanks
    Robert
  • Robert H Wood Oct 09, 2010
    Yes
    President:
  • 2,777 Answers
Well one easy way to find out is to get a replacement belt, try it, and if you have the same situation you can return that new belt and go back to the old one. There could be a few other things that many cause a loose belt like that, but they are unlikely. I would start with the belt if it were me personally, and then once you have confirmed a new one does or does not rectify the situation carry on from there.
Let me know, Tim
Posted on Oct 03, 2010
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    Let me research this further, want to make sure I steer you in the right direction. If you don't hear from me in the next hour or so please write back to remind me.
    Thanks
    Tim
  • Tim Grayson
    Is it possible to send over a picture of what it looks like with that new belt attached? I am still trying to figure this one out. If possible please attach one to your question here using the PICTURES button on the question box...
    Tim
I am having the same issue above but going to try and change the belt first. Seems stretched.
Posted on Sep 15, 2013
Have a 2009 John Deere LA115 and need a belt diagram.
For a belt (replacement) diagram, contact John Deere directly.
Apr 18, 2017 | John Deere Garden
What size drive belt fits John Deer L110 ?
The youtube video shows you how to replace it.
This webpage also has detailed instructions:
https://jdagccc.custhelp.com/app/answers/detail/a_id/486/~/transmission-drive-belt-replacement---100-series-hydro-42-in.
This should be the replacement belt you are after. Please confirm before purchasing. http://www.greenpartstore.com/John-Deere-Traction-Drive-Belt-and-Idler-Kit-GX20006KIT1.html
Nov 16, 2016 | John Deere L100 Series
John Deere lt155 traction drive belt adjustment
http://www.instructables.com/id/How-to-change-the-traction-belt-on-a-John-Deere-LT/the link shows the routing and idler spring either wrong size belt -inserted wrong or broken spring idler pulley
Sep 11, 2016 | John Deere Garden
Where can i find a John Deere la115 wiring harness diagram?
The John Deere site has the wiring harness diagram on the LA115 parts diagram in the Electrical section (section 40, page 19). Start here: https://www.deere.com/en_US/parts/parts.page and select the Parts Catalog. http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt is where I ended up. The carburetor is in section 30 (Fuel and Air), page 10.
I hope this helps.
Aug 03, 2015 | John Deere Garden
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
I need an illustration on how to change a drive belt on a john deere LA115 riding belt
http://outdoorpowerinfo.com/repairs/deere_110a_yellow_drive_belt.asp
Sep 24, 2013 | John Deere Garden
John deere x300 will not move
It sounds to me like the traction drive belt slipped off of a pulley or broke. The easiest way to get to the traction belt is to remove the mower deck. There is no easy way to replace the belt, however. It runs from the transaxle at the rear to the engine at the front, around idlers. Let me know if you would like assistance in replacing the belt and I can walk you through it, Daniel.
Oct 07, 2011 | John Deere 22HP Hydrostatic 42" Riding...
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Oct 14, 2009 | John Deere Garden
Garden Logo
1,667 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
