Question about GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator has stopped working, it is five years old. Could it be the fuse, where is the fuse?
    Sergeant:
    Champion:
  • 351 Answers
There is no fuse may be thermostat
Posted on Oct 03, 2010
    President:
  • 1,891 Answers
It could be the fuse located in the back on the main board . the fuse is not replaced by itself . the main board is replaced as a complete unit . part is about 160.00 .. .. mm
3 Suggested Answers
SOURCE: Our Danby propane refrigerator has
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Posted on Aug 03, 2008
  • 744 Answers
SOURCE: My refrigerator door comes open easily when the
Try to re-adjust the appliance so it is level and tips backwards slightly. You'll have gravity on your side to help keep the door closed. You will need help tipping the unit while adjusting the levelers underneath.
Also make sure the appliance is sitting on a solid surface and isn't somehow twisted, which will place stress on the box and possibly cause the issue you describe.
Make sure the unit is not overloaded and that the gasket surfaces are clean. After only 5 years, the magnetic gaskets should not be worn out.
Posted on Jan 27, 2010
Stopped working for no reason
Light on? Do the fans run?
May 10, 2013 | Refrigerators
Fridge stopped working both freezer and fridge, Here clicking at compressor, compressor not starting, cooling fan and everything else OK, could it be the compressor or is there a chance the thermal switch...
This is a bad compressor, or overload-relay kit. Disconnect the power, remove the overload-relay from the compressor, and test the three compressor terminals for continuity . You should have continuity between each terminal, and you should not have continuity between any terminal and ground. If this tests ok, then replace the overload-relay kit. This is a common repair for me, and it is very rare for us to find a bad compressor, so you should be ok. If it is a bad compressor, and it is less than five years old, you have a five year sealed system warrantee, that will cover the repair cost. If it is over five years old, it is not worth repair. When you are done with the repair, make sure you install a 2000 joule or higher, surge protector to protect your refrigerator from this type of repair in the future. Good Luck, Appliance Specialists
Mar 14, 2011 | KitchenAid Superba KSRG25FK Side by Side...
THE REFRIGERTOR JUST STOPPED WORKING IT IS 5 YEARS OLD AND NOT OVER USED
The overload/start relay may have gone bad.
Other possible causes:
* Bad thermostat. Check thermostat
* Defrost timer. Not definite but possibly bad. Last resort.
*Concentrate on getting the compressor to run first.
Once the compressor runs again, observe the refrigerator for a while to confirm cooling.
If there is no cooling after at least forty five minutes, your refrigerant may leaked out.
Do not despair, get the compressor running first. The worst case scenario would be a burnt compressor, and that has not been established yet.
Dec 22, 2010 | Magic Chef MCBR440 Compact Refrigerator
Kenmore Coldspot stop working
first ,do you have power to it,is the lights coming on?2-is there frost building in the freezer on the back wall?i think you have a defrost problem,let me know more-mike
Dec 15, 2008 | Refrigerators
Amana abb1922fe
Several. The icemaker broke twice, the freezer stopped working, and the compressor just broke. This is on a five-year old model, so if you buy this turkey, for god sakes get the extended warranty.
Jul 10, 2008 | Refrigerators
Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
May 26, 2008 | Dometic Refrigerators
Freezer
Check the back wall of your freezer section to see if it is icing up.  If so, you have an automatic defrost problem.  One or more of your defrost components (timer, defrost heater or bi-metal) has failed.  If there is little or no frost on the back wall, you could have a compressor related issue.  This is often indicative of Frigidaire refrigerators.  If the unit is less than five years old, the compressor is still covered under their warranty.  If it is the compressor and it is more than five years old, start shopping.
Oct 25, 2007 | Frigidaire FRS6R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
269 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
