Ignis Awd593 washer Can't find the pump. The sign has come up pump blocked. Can I do this or do I need an engineer
How do I open the pump access? I have tried and tried with no success
Posted on Feb 19, 2014
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: ignis washing machine awd593
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
SUZUKI IGNIS 2001 WHERE IS THE THERMOSTAT HOUSING LOCATION FOUND ON ENGINE
Find the top radiator hose..follow it to the engine block.. the thermostat is located at that junction...
Jun 13, 2017 | Suzuki Cars & Trucks
Ignis 1.5 sport 04
post all signs of overheating.
  1. dash guage
  2. STEAM eruptions>?
  3. AF (antifreeze ) leaks?
  4. CHeck engine light sticks on running?
  5. Scan tool shows way hotter than 200F? "ECT PID" parameter.
  6. oil in the AF? cold you see oil floating in the neck of the rad cap off?
  7. AF found on the A/T tranny dip stick end?
  8. Loosing coolant (drops) all the time, Check rad directly cold.?
  9. engine pings, (knock/detonation) ?
  10. lost power. from engine.
  11. shaking of engine. as it misfires.
  12. car heater makes this odd gurgling sound?
those are the signs but. what about precondtions.
overheats only parked< and never moving fast>
yes, bad RAD fan, (or its controls)
over heats all the time>?
fan belt fell off or slips?
clogged, rad tubes. (inside)?
water pump bad, blades, rusted to nothing.?
thermostat died, as most do way before 10 years,,,,,,,
clogged system from not doing the 2year service.
Mar 15, 2014 | Suzuki Cars & Trucks
Ignis dishwasher not working. When switched on a loud banging noise but there's no water?!
you need to take the drain pump off and clear whatever is in there. Pull the dishwasher out, remove the bottom cover or gain access to drain pump. Thats what it sounds like
Feb 14, 2013 | Dishwashers
I need user's manual for my ignis bella B60 washing machine
Sorry but FixYa cannot do that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 01, 2011 | Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Ignis ig 95 la user manual / operation manual
You will need to type into your search engine 'ignis washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 11, 2011 | Washing Machines
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine running, no water will pass through the pump.
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Dec 11, 2009 | Garden
Ignis washing machine awd593 ''clean pump'' indicator light has illuminated the machine has stopped working and we have lost the manual! please help
Oct 16, 2009 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
