Question about Kenmore Refrigerators
I have a Kenmore top freezer refrigerator Model No. 106.8609310. It is running, but not cooling. The compressor is hot to the touch.
The fridge is not cold enough to keep turned to the lowest setting, and the freezer is about the temp of what the fridge should be.
Posted on Jul 19, 2011
    Sergeant:
    Champion:
  • 351 Answers
May have lost its coolant
Posted on Oct 03, 2010
3 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: refigerator not cooling and hot to the touch
No, RD...
You can leave the fridge plugged in and it'll be safe. There's a safety device mounted on the compressor to insure this.
Now, have you checked the condenser fan yet? Is it turning? Seriously... the condenser fan is what is responsible for keeping the freon temp's correct. If the fan isn't working, you get "hot to the touch" between the fridge and freezer.
Please check the fan?
SG
Posted on Apr 06, 2009
caroldon
  • 17129 Answers
SOURCE: My kenmore elite top freezer
Switch off the fridge and after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The circulation fan must be checked to work as if frost forms it can be stuck up . So check if the defrost timer works and also if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Posted on Jul 26, 2011
Kenmore Elite fridge cools but we noticed the compressor and fan never turn off. Compressor is very hot to touch. Do we need to replace compressor or a relay switch or ...? Thoughts/suggestions?
Newer refrig. Run almost continuous but you could try cleaning the condenser coils, located on back with vacuum and brush also place thermometers in freezer and mid level refrigerator, freezer should run 0 to -8 F and refrigerator 34-37 F. If much lower adj. thermostat up.
Sep 16, 2017 | Kenmore Refrigerators
Usually the compressor feels warm/hot to the touch. Now it feels cool.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator not running, was a few days ago, copressor very hot
if compressor is hot it means (a) low charge (b) locked rotor and in any case it can be fixed
May 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Sep 30, 2008 | Frigidaire FRT17G4B Top Freezer...
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore upright freezer.
Will need a little more information to assist you with answers. Will need the model number if available for you Kenmore and will usually be on inside Freezer/refrigerator door and near bottom. Will look like model #363.1234567 for example.
Now if it's not cooling at all, is the compressor running beneath the fridge? Is the condenser fan running that is below the freezer and near the compressor? Is the evaporator fan blowing air in the freezer section? Do you hear clicking noises in the compressor area and can you feel the compressor to see if you feel warm or hot to touch around its side and top? Can you tell me of any other things that you noticed before the refrigerator stopped working? Is the temp control digital or manual settings? Has the settings been changed since you turned the refrigerator off and then back on? Thanks, Sea Breeze
Oct 28, 2007 | Freezers
Refrigerators Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
