Question about Linksys Wireless-G WRT54G Router
If it says WRT54G V8 does that mean it is version 8
  • 2,260 Answers
Yes that means the it is version 8 router.
click here for more information about the routers and networking
Posted on Oct 03, 2010
Hi, I have a Sony Ericsson Xperia Neo, and every time I want to connect with my WIFI the router reboots. This issue only happens with my Sony Ericsson Xperia Neo, other phones and devices work just fine....
Just had same problems with my brand new Xperia Mini Pro and old WRT54G ver 5. Every time I connected with WiFi the router restarted (once it returned to factory settings). I updated the router firmware to latest version (1.00.6 to 1.02.8) and after this it works fine.
Best Regards
Peder
Sep 17, 2011 | Linksys Wireless-G WRT54G Router
Wireless-G Broadband Router port forwarding
Need Model and Version number of your Linksys router. To find this info look at Tag on the bottom of your router, look for something like this WRT54G V8 (Model/Version). After that we can help you fix your problem. Thanks!
Oct 10, 2010 | Linksys Wireless-G Broadband Router
Cannot connect wii to router linksys wrt54g v8 i have switched my channels to 1 and 11. I have also updated my firmware to the newest version. I have also tried the manual setup but to no avail I have...
If you have Wireless MAC Filter Enabled on the Router then Either ADD the Wireless MAC Address of the Wii on the router or disable the Wireless MAC Filter on the router, also check the level of the Wireless Security supported by the Wii and accordingly set it up on the Router.
Mar 27, 2010 | Linksys Wireless-G WRT54G Router
Random reboots necessary.. possibly caused by surge or V spike
You have WRT54G router. check the version number of the router. If it is 5,6 or 8 then upgrade the firmware of the router. You will find the version number on the Flip side of the router. when you turn it upside down, you will see the model number and just after the model number , you will see the version number. Once you upgrade the firmware of the router, reset the router and reconfigure the router .
Click here for step by step instructions
Mar 06, 2010 | Linksys Wireless-G WRT54G Router
My internet will not connect by way of my rotter which is a WRT54G v8 Linksys. I've already connected direct from my modem but I need my router to work. the router address or number is 192.168.1.1 What do...
When you get the user name and password windows option enter the username "ADMIN" and in the password box "ADMIN" and press Ok. aftthat on the wirless tab check the security.
Oct 21, 2009 | Linksys Wireless-G WRT54G Router
Replacing spark plug wires on a 1981 cadilac eldarado. I m confuse where the wires go. i need diagram for replacing the wires. Its the 8-6-4 engine
Not sure what you mean by 8-6-4 but this will help you. Pick the correct one for your application:
GM (Cadillac) 250 (4.1L) V8 .GM (Cadillac) 273 (4.5L) V8 .GM (Oldsmobile) 307 (5.0L) V8 .GM (Oldsmobile) 350 (5.7L) V8 w/EFI.Engine firing order: 1-8-4-3-6-5-7-2 .Distributor rotation: counterclockwise
GM (Cadillac) 368, 425, 472, 500 V8.Engine firing order: 1-5-6-3-4-2-7-8.Distributor rotation: clockwise
GM (Cadillac) 429 V8.Engine firing order: 1-8-7-2-6-5-4-3.Distributor rotation: clockwise
Oct 06, 2009 | 1980 Cadillac Eldorado
Frimware Upgrade
Apparently not, but I'm guessing you already knew that.
http://www.linksysbycisco.com/US/en/support/WRT54G/download
Look carefully at the label and the firmware installed in your router. The 1.02.5 is listed for 5 and 6 only and version 8 is for 8 only. There is no 7 listed, so it was either a special run or there is just no firmware upgrade for it yet. It must have been perfect :-)
Carl
Mar 24, 2009 | Linksys Wireless-G Broadband Router
Windows Visa slow Internet speed with WRT54G version 8
A possible solution that could address both the slow Vista and the static IP:
  • Pls go to Start, Control Panel, Network Connections;
  • Right click on your Local Area networking and click on properties;
  • Highlight Internet Protocol (TCP/IP) and then click on the Properties button;
  • Tick on "Use the following IP address;
  • Enter IP address > 192.168.1.5;
  • Enter Subnet mask > 255.255.255.0;
  • Default gateway > 192.168.1.1;
  • The DNS would be what your ISP has set;
  • OK, close.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Linksys Wireless-G WRT54G Router
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
