Question about E-Machines eMachines Desktop PC
My computer won't start up out of safe mode
I turn my computer on and it tries to start up but after about 15 seconds it goes to a completely black screen. it will start up in safe mode but then i have no sound and some of the programs i have on it won't run. my computer was purchased in february and is an emachine.
    Master:
    Sergeant:
  • 461 Answers
This might be due to system registry, I'm not sure what operating system you are installed but below link might be useful for you to check the system registry and boot system failure...
http://etech.maiila.com/?p=27
and
http://etech.maiila.com/?p=24
If after doing above still doesn't work check your memory sticks.
All the best....
p/s : please don't forget to rate me... :)
Posted on May 27, 2008
I turn on my computer and i get a box that sais adjust screen and gives a resolution and then goes black, nothing else happens no beeps no booting noise. F10 pops up another screen for 2 seconds then goes...
try to boot in safe mode.To do that.
restart your computer continues press F8 key it will show the option select safe mode
and you can work with that and change the reasoluition and restart the computer work with normal mode..
Nov 13, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
I just recently acquired a Viewsonic VA521 LCD monitor from a friend who experience a power surge/outage. When hooked up and powered on, it shows the desktop for a split second, then seemingly goes black,...
It is possible that you can adjust your refresh rate. You may need another monitor to set the rate.
You may also be able to boot into safe mode. Try pressing F8 as soon as the system completes the POST (if you can see it). From safe mode, you can adjust the rate.
Can you get anything from the monitor without connecting to a computer? You should try to reset the monitor to its default settings.
May 20, 2010 | ViewSonic VA521 (Black, Silver) 15" LCD...
I have a 47 inch phillips hdtv and a hp elite cpu the hp eliute has a blue ray player there hooked up though a hdmi cord the tv starts up windows and shows safemode but when it goes to the password screen...
tv starts up windows and shows safe-mode. That right there is your problem, windows defaults the monitor down to regular 640 mode. I will cut out the hdmi since that is not a monitor. Safe-mode is used to trouble shoot your computer and it loads just barely the drivers you need to see and work with the computer. You will have to get the computer to boot up normally then proceed from there, also you will have to set up your video card to output hdmi.
Apr 25, 2010 | Computers & Internet
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Aspire 2920 won`t start up
As it's rebooting try tapping the F8 key to get to safe mode. Choose Safe Mode with cmd prompt first. Once your pc starts enter the text chkdsk /f in the black DOS box and reboot. The laptop should go though a check disk and fix problems. May not completely repair your laptop, but it's a start.
Mar 17, 2009 | Aspire Acer 7520-5071 Notebook
Problem with my T5224
Try booting to "SAFE MODE" then see how much free space is left on the hard drive.
Also in safe mode, defragment the HDD if you have not do so in awhile.
You need a minimum of 15% free space for XP oe ME to run.
Feb 19, 2009 | E-Machines T2742 PC Desktop
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Problem with starting up me dellE153FP
Try turning on your computer and keep pressing F8 and it should bring you to a menu. Choose "safe mode" and see if you can get into safe mode. If you can get into safe mode and then go into system restore and choose a date back to when you computer was last working properly for you. If you can't get into safe mode and goes back to a black screen then your OS is corrupt and you'll need to wipe out the hard drive and restore you computer back to factory defaults.
Feb 02, 2009 | Dell E153FP 15" LCD Monitor
I have a Dell GX60 and I changed the display resolution and
So, with The computer, completely turned off, Turn it on, Can't you see the BIOS screen? , or a Dell LOGO?
It is when you see this BIOS or Dell logo Screen that you Need to:
  • PRESS F8
  • Press F8
  • Press F8, again, and again right when your computer turns on.
Then You should be brought to the Window that allows you to boot into SAFE MODE, DO NoT PICK SAFE MODE.
Pick: ------------ENABLE VGA (basically safe mode) Only!.
Once booted, log in and change the resolution to let's say 800x600,
then restart your computer normally.
You should then be able run windows normally, (Without F8 Key) where you can then change the resolution to what you want.
IMPORTANT! Remember this, if you set your display to a resolution that it Does Not
support, and the screen goes blank. DO Not Turn off your computer: ALL YOU DO IS PRESS
the (Esc) ESCAPE Key within 15 Seconds and your monitor's resolution will be set to it's
previous state again.
I Hope This Helps.
Jan 30, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
E-Machines eMachines Desktop PC Logo
44 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
