Question about Dishwashers
Top spray arm rubber hose connection on top of dishwasher is leaking. I found some kind of wax style goopy sealant where the hose enters the top. what is this stuff, and how can i seal this connection again ?
  • jeff archer Oct 04, 2010
    The dishwasher is a GE # gsd5330d01ww
    This is a sealant prefered by techs to seal components of a dishwasher?
  • 10,865 Answers
Hi. Yes you can seal it again or just buy a new assembly at searspartsdirect. I would reseal it. Go to the hardware store and get a tube of adhesive called plumbers Goop. The stuff works great. Joe
Posted on Oct 04, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the manufacturers name and model no# of your Dishwasher so that I can further assist you.
Thanks
Rylee
Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
Hello there:
If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Dishwasher leaks from bottom left corner
If its just that corner check that it is level (if not leak could be somewhere else)
Then check your hoses and valves for holes or leaks (try putting some food dye water when running to see easier
Most likely a loose hose connector or hole in the rubber hose
This hould help you
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Leak from a black module, where an arm connects
if your dishwasher leaks check out this: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
Oct 11, 2008 | GE Nautilus 24" Built-in Dishwasher
Kenmore dishwasher not cleaning
Growand:
There is a rubber tube which supplies water to the top spray arms. That is, If yours has top spray arms. This rubber tube has to make a connection when one slides the top rack back in. That tube will rot after a while, check it out.
If the soap is not being used up, reduce the amount of soap you are using and run the dishwasher empty with a pie plate sitting on the bottom rack with a cup of distilled (cheap) vinegar in it. Run it hot and long, recheck and redo if neccessary.
Jul 30, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Danby counter top dishwasher leaks
This might help with disassembly. Mine was leaking also, but my main problem was no spray. Use my disassembly instructions to remove the pump/motor. If you notice that the leakage is from the pump and not a loose connection, remove the pump cover and apply a thin bead of Blue RTV sealant to the rubber ring. This stopped the leak in my pump.
________________________________
My Danby dishwasher (DW) stopped working. The spray arm stopped spinning completely and very little water was coming out of the arm. When I removed the spray arm (CAUTION: reverse threaded, turn CW to loosen and CCW to tighten) and ran the DW, very little water was spraying out of the pump.
I thought maybe the pump was clogged. So, I followed the recommendations I had seen online about running a few cycles with Vinegar to clear the crud from the pump, but this did not help.
It seemed like the motor was operating, and there were no strange smells to indicate the motor was burned…just no water spraying. So I thought it must be the pump. Before disassembly, I tried to locate a replacement pump. I searched far and wide, both locally and online, and could not locate a replacement pump. So with nothing to lose, I decided to disassemble the DW, take a look and see what I could find. I am glad that I did.
The bottom line is that I disassembled the dishwasher and found that the plastic pump impeller had worked its way off the pump shaft and was not turning. I forced some Teflon plumbers tape over the shaft and forced the impeller back onto the shaft. The impeller has a flat spot to line up with the shaft and I pushed the impeller down on the shaft as far as it would go. I then used a small socket to fit over the shaft and GENTLY tapped the impeller for a final seating. I reassembled the dishwasher and it worked like a charm.
Since I could not find any service manual or instructions online for this DW, I thought I would share my disassembly/reassembly procedure.
Since my instructions are too long to post here, a complete repair document including a link to pictures can be found at:
http://www.megaupload.com/?d=XBOGBR4I
Jan 11, 2008 | Danby 22 in. DDW399 Free-standing...
Top rack not cleaning and spray arm possibly not moving
I removed the lower arm, the strainer, and three screws (Torx, but I used small allen wrench). I took of the pump cover, and found a small white ball blocking the tube that goes to the top rack sprayer. I put everything back except the ball. It has worked well ever since.
Nov 03, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
