Question about FUJIFILM FinePix AV100 Digital Camera
Hi trying to use my camera today, previously working fine, getting protected card warning on the screen. unable to use what do i do please?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Oct 03, 2010
My sony camera is giving me a warning message, "unable to use card"
Try another card, and look for scratches or damage on the gold strips on the card. Check the manual to see which way it goes in the camera.
Nov 25, 2013 | Sony Alpha DSLR-A350K Digital Camera
Screen is black and memory card should not be full,
the error could be due to several things - the card reader, pins bent, card getting hot or near magnetic source...
go ahead and re-format your card, even though u might risk never being able to retrieve your photos.This is better cuz if u send it for repair they will charge between $100-$150.
But I found a free recovery software called Zero Assumption Digital Recovery (http://www.z-a-recovery.com) which will able you to recover photos.
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Nikon COOLPIX S6 Digital Camera
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
I have Panasonic DMC-ZS6 Lumix w/4gb memory card - has worked fine until today- now window says
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2012 | Panasonic Lumix DMC-ZS6 Digital Camera
Sony A100:put in empty CF cards, says card full, won't format
Might be 2GB card is more then enough for camera hardware o handle. Try 1GB card in this camera.
Mar 15, 2009 | Sony DSLR-A100 K Digital SLRCamera Digital...
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Warning:Unable to use the card, so i can not take a photo!
hello,
Try too format your CF card in FAT (not fat32) in a computer.
Oct 17, 2008 | Konica Minolta DiMAGE 7 Digital Camera
Problems need help A.S.A.P please
Try reformatting the card. If the camera will not allow you to reformat it there, try doing so on your computer.
Sep 22, 2008 | Fuji FinePix F700 Digital Camera
Card format problems
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Aug 27, 2008 | HP Photosmart M527 Digital Camera
Black screen
whats up with blackscreen?
Oct 08, 2007 | Fuji FinePix F460 Digital Camera
FUJIFILM FinePix AV100 Digital Camera Logo
47 people viewed this question
Top FUJIFILM Cameras Experts
Steve
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
