Magnum 330 canister filter instruction manual
2 Suggested Answers
Milrite
  • 79 Answers
SOURCE: 330 Magnum bogs down.
NO! Check the boot between the carb and engine. Very common problem for aged rubber is non-visual cracks. Pull it off and check the boot by kneeding it and looking at it under a light.
Posted on Jan 16, 2010
Why will 2005 Polaris Magnum 330 fan not stop running when the ignition is turned off? The running fan drains the battery.
replace the faulty fan relay or check for a problem wire from the ignition to the sensor to the relay
Mar 03, 2016 | Polaris 2005 Magnum 330 4X2
Polaris330location of fuse box
follow this link for a owners manual , i have searched through and there is no fuse box , as with most motor cycle type vehicles there is usually just one fuse directly from the battery positive terminal which is a easy way to keep the electrical system safe and only have one fuse to check etc
Polaris Magnum 330 Owner Manual Battery Removal
Jul 19, 2015 | Cars & Trucks
Where is fuel filter? located
Polaris fuel filters are usually in the fuel line coming from the valve that turns fuel off. This model does not seem to have an inline filter, however you can always buy a universal one and splice it into the line so that then it does have one
Mar 13, 2015 | Polaris 2006 Magnum 330 4X4
04 330 magnum will not stay running without choke pulled out halfway to full choke from brand new in 2004
First make sure the carb.mounting flange is tight. being loose or cracked will allow air in leaning out the air fuel mixture. Next remove the low jet in the carb. its most likely plugged. try carb cleaner and blow it out with compressed air. Last resort,take the paper off of a twist tie and run it through the jet. If all else fails,buy a new one.thier only around 4 dollars.
Dec 14, 2014 | Polaris 2004 Magnum 330 4X4
Why is the in side of my magnum 330 filter not sucking up water
check to see if intake unions are tight if so you might check the top gasket
Oct 01, 2014 | Pool & Spa
Where is the voltage regulator located on the 2005 polaris 330 magnum 2x4?
2005 Polaris 330 4x4 will not go in 4x4 unless i press an hold the over ride button. an what dose the ( E ) stand for on the speedometer ... like it should say ( H.L.N.R.P) any ideas
Jul 30, 2012 | Polaris ATV
Jan 15, 2010 | Polaris ATV
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
