Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
I have a min kota trolling motor ser. #2050 mod.#CDR121 IT HAS A CURVED SHAFT 31" long a 12 volt motor 9" long by 4" diameter on top of the shaft. can you tell me what year it is?
  • 35 Answers
Click on to.." Northland Marine.Com ..they can help with you're inquiry.
Posted on Oct 03, 2010
I have a Minn Kota Fortrex 80" Shaft 24volt motor. The shaft appears to have a lot of play where it connects to the top of the aluminium bracket at the head. How can I repair this?
what do you consider a lot of play
1/2 inch, 1", .02",040" or what
talk with a service agent for the equipment to get the exact amount of end play permissible or down load a workshop manual for the equipment
Mar 10, 2016 | Minn Kota Fortrex 80 Bow-Mount Trolling...
What spec battery is the best for the Minn Kota 40 Endura trolling motor?
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
May 19, 2011 | Minn Kota Endura 40 Transom Mount Trolling...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
How do I remove the composite shaft from the motor housing
I just replaced the shaft (composite) on my Endura 34 today. First, remove the crossbolt that attaches the control head to the top of the shaft. Second, remove the top cover of the control head. Third, make note of the wire connections within the control head (take a picture) and then unplug the red, yellow, white and black wires...no need to unplug the main 6 guage red and black power wires. Fourth, with the wires unplugged, pull the shaft with motor housing attached through the transom mount assembly. Fifth, immobilize the motor housing (gently vice?) and heat the socket in which the shaft screws into motor housing. Do not overheat, only use enough heat to soften factory sealant making unscrewing shaft possible. Sixth, reassemble in reverse order.
Notes: Do not use a pipe wrench as this will crush the composite shaft, either old or new. Apply thread sealant prior to installing new shaft (I used Permatex Thread Sealant/Formagasket). Ensure crossbolt hole on top of shaft aligns with motor housing below.
Apr 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
GPS Logo
254 people viewed this question
Top Minn Kota GPS Experts
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
