Question about Sharp Vacuums
Why is my making a really loud noise and smells burnt when I turn it on. I have a new belt on it.
  • 694 Answers
Improper installation of belt can result in a loose or off center belt which will flap and make lots of noise. It can also result in the burning rubber smell. The belt is probably ruined now, and will need to be replaced again. Make sure new ones are installed and centered correctly.
Posted on Oct 04, 2010
I brought a shark need to know if i can get it fix motor making loud buzzing noise it should be still under warrnty
Motor is jammed or burnt out,is there a burning electrical smell?,if there is,and the belt on the motor turns freely by hand , then the motor is burnt out.
Jan 11, 2015 | Shark Navigator Bagless Upright Vacuum
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Burning smell
The motor is burnt out. Good news is that most central vacuums are really easy to get into so replacing the motor shouldn't be too hard. I haven't worked on that exact machine but the fault is unmistakable.
Jun 26, 2013 | Electrolux Central Vacuum
When i plug it in it makes a loud noise and produces smoke. that smells like something is burning
SOUNDS LIKE YOUR BELT IS BURNT OUT, YOU'LL NEED TO TAKE OUT AND REPLACE. Try Sears for this part. An inexpensive part.
Dec 07, 2010 | Vacuums
The belts not turning
for sure the fan is broken that was the noise has to be replaced if you didn't feel any burning smell the motor still good also the first thing should be replace the belt for a new one the old one might be worn
Jun 11, 2010 | Electrolux EL5020 Vacuum
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My vacuum is loud and dies
your impeller is broken that make motor work harder and shut off
Oct 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Vacuum is making a loud noise
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Dec 03, 2007 | Kenmore 35622 Upright Vacuum
Vacuums Logo
310 people viewed this question
Top Sharp Vacuums Experts
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
