Question about Pride Go Chair Travel Power Chair
Controller light is flashing and chair will not move
  • 692 Answers
Sandi Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. This will give you the flash error code and your users manual should tell you what the number of flashes indicate. (for example 3 flashes bad brake) Also check to make sure your scooter is not in freewheel. Turn off the scooter and move the freewheel lever in and out of gear a few times then turn the scooter on and see if you still get the flashes. If you can't figure out what is wrong then contact your provider and ask if they can check it out for you. Hope this Helps
Posted on Oct 04, 2010
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Sep 28, 2012 | Pride Mobility Products Pride Jazzy 600
Llightw start flasHing and chair will not move.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Dec 12, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
When turning on joystick control the chair moves but when i stop the lights start to blink and stops moving horn works if i play with the on/off it start to works agian
fantasy when it stops count the number of flashes. For example it might flash 5 times pause flash 5 times pause etc. This is the flash code and your manual will give you what it means. Being an intermittent problem can be a bear to trouble shoot. It would be nice to know what chair you have and whether Medicare purchased the chair for you. If Medicare purchased the chair then they will pay for most of the repair cost Hope this helps you
Sep 10, 2010 | Health & Beauty
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
All lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
These will tell you what the fault is; repost with more information.
May 23, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Pride Go Chair Travel Power Chair Logo
556 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
