Question about Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher
Lower arm in dishwasher not cleaning the items in the dishwasher
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
How do I clean out filter in maytag dishwasher Model number DWU8260AAX
To clean the filter what ya do is
remove the lower rack
unscrew the center wash tower off of the lower wash arm
remove the screws from the pump cover (the almost frisbee shaped part with the stainer around the bottom of it)
lift off the pump cover...directly below the pump cover will be the filter it will pull off and can be cleaned in the sink.
this link is a drawing of the pump for your model http://c.searspartsdirect.com/lis_png/PLDM/M0112066-00006.png
the center wash tower is items# 1,27
the screws for the pump cover is item # 5
the pump cover is item # 4
the filter is item # 6
GENE
Oct 06, 2011 | Dishwashers
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
After we wash and the dishes dry, we find grit on the (mostly) top shelf items. That is glass and cups. We check the arms they are free and not blocked. We tried lowering the top shelf, rearranging things...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 24, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
Dishwasher
How to Buy
heatman101
Feb 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore dishwasher #665 only sprays water for a sevcond. will run cycles just won't spray more than a second
This is a sign of food particulate that is blocking the impeller inlet under the lower wash arm. Remove the lower wash arm noting EXACTLY how it comes off as you remove it. Then clean out the particulate. You may have to unscrew the lower wash arm tower also to get to the particulate.
Once yopu get it cleaned out it should work just fine. This does not happen often but..it does happen. It should not repeat anytime soon.
If you need exact instructions with part details I will need your full model number.
I think this is your dishwasher:
http://c.searspartsdirect.com/lis_png/PLDM/10054505-00004.png (Enlarge)
You may have to remove Item 14 (ONLY) to clean off the screen Item 1
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Kenmore Dishwashers
Dishwasher does not clean items on top shelf.
Check the upper spray arm holes for debris that may be plugging up the spray arm. If clean remove the lower spray arm and filter screen and clean out any debris in the sump.
Feb 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
LG dishwasher does not seem to clean items on lower rack
Can you tell me if the problem was fixed by the original posters?
The multi-level wash direction feature uses a check valve just below the mesh filter asembaly and is driven by a vario motor underneath the check valve. By removing the mesh filter (10 screws and the lower spray arm) you expose the check valve. It is very close to the pump that empties the water through the drain hose.
High probability problems: -The Check Valve could be jamed/stuck. -Also, the Vario Motor could have failed
Please respond back with the findings on this problem. Thanks!
Sep 29, 2008 | LG LDF6810ST Stainless Steel Built-in...
Spray arm not attached
You may have stripped the threads on the spray arm or spray arm support. I believe the threads are reverse-threaded and since they are plastic, can easily be stripped if turned in the wrong direction. This has happened to me before. The solution is to replace the lower wash arm and spray arm support. You can find the parts at repairclinic.com. Just type in you model number and look for item numbers 830883 (spray arm support) and 9040141 (lower wash arm). You may also want to check out searspartsdirect.com as well. The parts will be located under the "Lower Washarm and Strainer Parts" section. The two sites do offer comparable pricing. Post back if you need further assistance. I hope this helps you.
May 04, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Maytag 24 in. MDB8600AW Jetclean II Built-in Dishwasher Logo
44 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
