Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I replaced the distributor cap and the spark plugs in my '79 440 dodge class C RV. I screwed up the distributor cap wires.I need firing order and location of #1 plug wire on distributor cap.
  • 4,349 Answers
The easy way to find #1 is to pull the #1 plug, ground the coil, place finger over the #1 hole, crank over till compression stroke, and then look at the rotor, and it will be pointing to #1 position. It may take a few times before you can get it correctly stopped at this position...
Posted on Oct 03, 2010
Testimonial: "Looks like that is the only way to find #1. I couldn't see the timing marks on the torque converter. It started to rain so I quit for the day. Bill"
No spark to engine 1991 ford pickup
It can be faulty or dirty spark plug itselfd.Also for reference get the fuel level checked.Is the fuel tank is empty or near to empty.
Try cleaning the spark plugs and then see if that is helpin.On some cases the black carbon layer gets collected on the spark plugs and that causes the problem,so cleaning the plugs help.But if its not helping,then spark plug has to be replaced.Spark plugs get power from ignition coil to ignite sparks.If ignitioncoils are faulty then also there will no spark.--------------
To troubleshot and confirm the issue,i suggest you to go through the help links provided below,check the procedure and it will help you to confirm the issue in your case.
Click the link below:------
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in 1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
How does the spark plug wire go on the distributor cap in 1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Spark plugs and wires
It sounds like the spark plug wires are not plugged into the correct place on the distrubutor. take the distributor cap off and crank the engine over. Make a note of which direction the rotor spins. (Clockwise, or Counterclockwise) then find the firing order for that engine. Sometimes the firing order is on the intake manifold. (if you tell me which engine it has, the 4 cylinder 2.0, or the 6 cylinder 2.5; I could post you the firing order). Now on the distributor cap there is one wire post that has the #1 on it, that would be where you put the spark plug wire from cylinder 1. Following the rotation of the distributor rotor, you would put the spark plug wire for the next cylinder in the firing order after the #1 wire, and so on.
Dec 11, 2011 | 1998 Ford Contour
2001 dodge ram 1500 5.2 v8 van spark plug diagram
firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
Distributor cap diagrahm for a 1992 dodge dakota 3.9 L what is the correct order for the spark plug wires on the distributor I know the firing order is 1 6 5 4 3 2
Here is a firing order diagram and note the distributor cap latch positions between terminals 1 and 2 and 5 and 4, and let me know if you need any help to understand this diagram or if you require any further assistance.
Oct 21, 2010 | 1992 Dodge Dakota
Need a diagram for the firing order for a 1998 Dodge durango 5.2 engine. I think I mixed the wires up. Help!
Firing Orders NOTE: To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
If a distributor is not keyed for installation with only one orientation, it could have been removed and installed improperly and then rewired. The new wiring arrangement would maintain the correct firing order, but could change the relative placement of the plug towers in relation to the engine. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes of the current plug wire locations and orientation of the distributor cap.
1-6-5-4-3-2
5.2L Engine 1-8-4-3-6-5-7-2
5.9L Engine Firing order: 1-8-4-3-6-5-7-2
Oct 12, 2010 | 1998 Dodge Durango
Just wondering if you have a breakdown diagram for a 1992 dodge colt 1.5l distributer
I do not have a breakdown diagram for a distributor, but just the firing orders and description of ignition system for the Dodge Colt and related models (based on Chilton manuals) if that's what you're looking for: FIRING ORDERS Fig. 1: 1990 1.8L SOHC Engines Firing order: 1-3-4-2 Rotation: clockwise 84182009.gif
Fig. 2: 1.6L DOHC Engine Firing order: 1-3-4-2 Distributorless Ignition 84182010.gif
Fig. 3: 2.0L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182011.gif
Fig. 4: 1.5L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182012.gif
Fig. 5: 1993 1.8L Engine Firing order: 1-3-4-2 Rotation: counterclockwise 84182013.gif
Fig. 6: 2.4L Engine Firing order: 1-3-4-2 Rotation: clockwise 84182014.gif
To avoid confusion, replace spark plug wires one at a time. --- Distributor REMOVAL & INSTALLATION Although the distributor can be removed from the engine no matter which cylinder is about to fire, it is a good idea to have number one cylinder at TDC before distributor removal. 1.5L, 1.8L, 2.4L SOHC Engines
  1. Disconnect the negative battery cable.
  2. Disconnect and tag the spark plug wires from the distributor cap.
  3. Disconnect the distributor harness connector.
    Fig. 1: Ignition system for the 2.0L engine 84183001.gif
    Fig. 2: Ignition system for the 1.5L engine 84183002.gif
    Fig. 3: Ignition system for the 1992-93 1.8L engine 84183003.gif
    Fig. 4: Ignition system for the 2.4L engine 84183004.gif
  4. Loosen the distributor retaining bolt and remove the distributor from the engine. To install:
  5. Rotate the engine until No. 1 cylinder is at TDC on its compression stroke. NOTE: Be careful not to turn it to the No. 4 cylinder TDC on its compression stroke by mistake.
  6. Align the distributor housing and gear mating marks.
    Fig. 5: Ignition system for the 1990 1.8L engine 84183005.gif
    Fig. 6: Distributor installation for the 1990 1.8L engine 84183006.gif
    Fig. 7: Distributor installation for the 1992-93 1.8L engine 84183007.gif
  7. Install the distributor into the engine, while aligning the fine cut (groove or projection) on the distributor flange with the center of the distributor mounting stud.
  8. Install and tighten the distributor retaining bolt.
  9. Reconnect the distributor harness connector.
    Fig. 8: Distributor installation for the 2.4L engine 84183008.gif
    Fig. 9: Distributor installation for the 1.5L engine 84183009.gif
    Fig. 10: Distributor installation for the 2.0L engine 84183010.gif
  10. Install the distributor cap and spark plug wires.
  11. Reconnect the negative battery cable.
Oct 11, 2010 | 1992 Dodge Colt
I took of*** my spark plug wires working on my small block 350 pickup and I don't remember the the firing order to put the new wires back on. Is there a diagram anywhere or is it even that difficult to...
Next time number each lead before you remove it and no. the dissy cap as well
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
Jun 21, 2010 | Cars & Trucks
What is the firing order for the 1994 ford taurus 3.8 engine, have just replaced cap and rotor, need order, thought I marked them but engine will not start. Perhaps I was wrong in the order.
Not trying to insult your intelligence, I'm going to get pretty basic here,
Looking at the Front of the engine, the spark plug order is 1, 2, 3, and 4. Front to back.
Looking at the distributor, it has two mounting screws for the distributor cap. One is close to the engine, the other screw is on the other side.
Looking at the distributor cap screw, on the Far side away from the engine, Number 1 spark plug is on the tower to the Left of it.
To the right of this distributor cap screw, is Number 2 spark plug tower.
The rotor turns clockwise.
Again, looking at the distributor from a top view, there is a distributor cap screw at the top, (Close to engine), and a distributor cap screw at the bottom.
Drawing an imaginary line from the top screw to the bottom screw, Number 1 spark plug wire goes to the Left, of the bottom mounting screw.
Firing Order is 1-3-4-2
The rotor turns Clockwise, (To the right)
Aug 03, 2009 | 1994 Ford Taurus
Need a distributor wiring diagram for a 1989 dodge 150 van 3.9L
The firing order is 1-6-5-4-3-2 in a clockwise direction. Number 1 should be marked on the cap. 1 3 5 are on the driver side, 2 4 6 on the passenger side. I hope this helps.
Apr 10, 2009 | 1989 Dodge D150
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
304 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
