Question about Dell Dimension 4700 PC Desktop
I have my dell dimension 4700 connected to the internet through my modem, but when i go to get on the internet on it, it says that it's not connected.. i just want to know what to do to get it working
5 Suggested Answers
Hollyecho
  • 313 Answers
SOURCE: Hard drive size in a Dell Dimension 4700
nope, have one here that I put a Terabyte drive in and it is working great.
Posted on Jul 02, 2008
dante777
  • 623 Answers
SOURCE: dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Posted on Mar 31, 2009
efs_perpends
  • 1996 Answers
SOURCE: audio driver for dell dimension 4700 will not work
This tutorial will guide you through the process of updating your hardware driver. If you have the recovery disk from dell, you will have on it a copy of the original drivers for your sound device. See also this dell support article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 03, 2009
  • 240 Answers
SOURCE: dell dimension 4700 NIC problem
Reinstall the software that came with your network adapter.
Posted on Dec 02, 2009
I have a dell dimension 4700 and i cant install local network conection
The first step is to find drivers for your Dell Dimension 4700 and look for network and install the drivers to your computer and see if that works.
Here is the link to your driver area. Support Drivers
Apr 04, 2013 | Dell Dimension 4700 PC Desktop
Cannot connect to internet, recent documents, etc.
Hello try to scan for malware, with this program:
http://www.malwarebytes.org/products/malwarebytes_free/
Please decline the pro version.
Try also to install microsofts own antivirus program:
http://windows.microsoft.com/en-us/windows/security-essentials-download
Save both installation files on a usb disk.
Please uninstall any other antivirus programs, before you install this.
Run a full scan for virus, when the 2 programs is installed.
Start with malwarebytes.
Check also for driver updates here at dell:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4700
Hope this will get you running again.
Mar 16, 2013 | Dell Dimension 4700 PC Desktop
Fax modem sound volume
Go into the device manager and select the modem to change the volume.
Click Start/Control Panel/System/Hardware/Device Manager then scroll down to Modems and click the + sign next to Modems to expand and see your modem. Right Click on your modem and select Properties. When the Properties window opens up click the Modem tab and then select to change the Speaker Volume. Just slide the volume meter to the right by using your mouse pointer to increase the volume.
Apr 18, 2012 | Dell Dimension 4700 PC Desktop
Does a Dimension 4700 have an internal fax modem?
Hello
This unit does have an internal Modem, all you will need to do once the cable is plugged into the computer, you will need to load software which will enable you to send faxes from your computer.
Please feel free to let me know if you have any further questions.
Kind regards
Lock123
Dec 14, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell dimension 4700 NIC problem
This is very common after a fresh installation of the OS. Simply go to Windows Update and run it a couple of times. Upon reboot, the system will detect your hardware and you'll be back in business!
Dec 02, 2009 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 - Driver Reset
1st you need to download or install all the drivers for your Dell computer. Try to use the drivers/utilities disks first. Once you can get online, go to Dell.com and look up your model 4700 and download all the missing drivers. Your Linksys Router is not a modem. The Linksys has the modem connected to it for wireless connections.
Jul 04, 2009 | Dell Dimension 4700 PC Desktop
CAN'T CONNECT TO ISP USING ETHERNET NETWORK PORT DIMENSION 4700
make sure the cable is in the correct place. (8 ping plug-little bigger that the phone plug.)
1). start>>control panel>>system>device manager.
make sure there is not "red X" or yellow!" ont he network card.
if that is OK. right click on "my network place" on the desktop>>local area connection>> right click on properties again.
you will see the network card name, and select TCP/IP under the " This connection use the following item" box. Click on properties.
make sure the " Obtain the IP address automatically and the "Obtain DNS address automatically" are check.
shunt down the computer
wait 2 minutes, restart the machine.
open the Internet Browser after the machine finished loading.
Dec 16, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
