Question about Ace Hardware Living Accents Patio Heater Cover
Patio heater has a large yellow flame near the pilot lighting area after it has been lit. When the burner runs for a few minutes the burner shuts off. What is causing the problem? How do I fix?
2 Suggested Answers
  • 8404 Answers
SOURCE: Out of the box the patio heater didn't work and I
If it is beyond any adjustment period from Ace, I suggest you take this to a full service propane service center for repair. You shuld first check with your Ace hardware man.
Posted on May 16, 2010
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
I have a Whynter ph-2100h and the pilot will not light the burner nor will it stay lit once i have ignited the pilot. The gas runs for approximately five minutes then shuts down completely.....help
I would think the thermocouple isn't working. The thermocouple provides the power to open the gas valve. One end of the thermocouple should be in the pilot flame, it is on the end of a small copper tube that connects to the gas valve. Make sure you are following ignition instructions. Hope this helps ya.
Dec 22, 2010 | Whynter SOLARIS 41000BTU Outdoor Propane...
I have a Kirkland Patio Heater Model PTH-106SS-3G that will not stay lit. The pilot light works but when I release the knob it goes out. On the occassion that I can light the main burner it only stays...
Hi and welcome to FiXya I am Kelly.
Your pilot light burning yellow is a sign of a dirty orifice. This can be caused by insects or a spider web in the pilot air supply.
To clean the air supply / orifice area see this page:
http://www.nexgrill.net/trouble/p1.5.html
Also the thermocouple may not be close enough to the flame. You won't know this for sure until you finish cleaning the pilot / orifice area.
This link has step by step links for all of the components / causes of a pilot not staying lit. Click each of them and it will bring up a pdf file with step by step instructions and pictures:
http://www.nexgrill.net/trouble/p3.html
A bad thermocouple can also cause this. Givien you have a yellow flame I do not think this is your problem. But if it ends not staying lit after cleaning see this page on how to get to the thermocouple:
http://www.nexgrill.net/trouble/p2.2.pdf
Thanks for choosing FixYa.
Kelly
Sep 05, 2010 | Garden
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
The pilot light is hard to stay lit and when it does the burner only stays lit for a few seconds and then abruptly burns out.
If you have athermaocouple on unit it could be going bad. It is the copper line that the head sets in the flame they just go bad. Also if your pilot is not large enough it will cause the tcouple not to work. You may have to take a small wire and clean out pilot. but most of the time it is the thermocouple and you can pick one up at a hardware store. Rus
Nov 22, 2009 | Endless Summer 153100 Open Flame Patio...
Have Endless Summer patio heater. I got the burner to run but after 3-5 minutes the heater shuts down. Also having problems getting the unit to fire after lighting pilot light Maybe thermo coupler?
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Oct 21, 2009 | Endless Summer 2009 Open Flame Patio...
Pilot and burners
You need to check a couple of things, first is the flame sensor, second is the thermostat. Without anymore detailed info this is the most I can give you.
Nov 08, 2007 | Uniflame 200209 Open Flame Patio Heater
Patio heater won't stay lit
I had this same problem - here's how I fixed it...
First: Never modify the safety features of your heater as has been suggested elsewhere on this forum. Modification of these features may allow the heater to work, but greatly compromises the safety of anyone near the heater.
The problem with the heater shutting off is most likely due to not enough gas flowing through the pilot orifice (this orifice is almost as small as the diameter of a human hair). When this happens, the pilot flame does not burn vigorously enough to activate the thermocouple. Hence, the thermocouple shuts off the gas and the burner goes out - usually you'll hear one "click" when this happens.
This is a maintence thing - meaning you may have to do this as a seasonal activity.
Here we go....
(1) Shut off the gas at the tank - or remove the tank entirely.
(2) Remove the screws that hold the burner shield and top shroud from the unit - set it aside.
(3) Remove the control knob - it just pulls straight off.
(4) Remove the panel immediately behind the knob you just took off. This will expose the gas valve assembly.
(5) Remove the cover that encloses the bottom of the pilot light/igniter (assembly). This will expose the bottom of the pilot assembly.
(6) Remove the screw holding the pilot assembly - there is a small hex nut on top, but under the burner that you'll have to hold to prevent it from turning. This will free the pilot assembly allowing you to gently pull it out of the pilot assembly housing. DON"T pull hard or you may break the gas line or thermocouple.
(7) Remove the hex nut that attaches the gas line to the pilot assembly and gently pull the gas line out. At this point, to ensure you have gas flowing through the pilot gas line, you may want to re-attach the gas tank, turn it on, gently move the gas line as far away from the spark ignitor as possible, temporarily replace the control knob, and turn the knob to the "Pilot" position & push it in. DO NOT DO THIS ANYWHERE NEAR AN OPEN FLAME OR A LIGHTED CIGARETTE! You should be able to hear a hissing sound as the gas flows. If you do not hear it, the problem may be with your gas valve, and if that's the case, I'm sorry this procedure likely won't solve the problem.
(8) Remove the pilot light tube (orifice) from the mounting bracket. There's a hex nut on the back side that holds it in. Be careful not to damage the hex nut or the threads. You'll need a pair of pliers (to hold the bracket) and an adjustable wrench for the hex nut. Make note of the orientation of the pilot burner diverter so you can put it back together the same way it came apart.
(9) Using a blast of compressed air, blow air through the pilot orifice. You should be able to see just a very (and I mean very) small pin-point of light through the pilot burner. If not, use a single strand of very fine wire - like one strand from a 18 gauge braided electrical wire - and run it through the pilot orifice. Carbon build-up can clog this orifice - which can prevent the pilot from burning vigorously enough to heat up the thermocouple. Cleaning it out periodically will likely solve the problem.
Put everything back together in reverse order as noted above - making sure your gas fittings are tight and don't leak. Once it's all back together, light the pilot flame as normal and once the thermocouple heats up, the heater should work like a charm.
Oct 03, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Ace Hardware Living Accents Patio Heater Cover Logo
151 people viewed this question
Top Ace Hardware Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Ace Hardware Pool and Spa Expert? Answer questions, earn points and help others
