Question about Frigidaire GLER341A Electric Dryer
How do I remove the drum of a Frigidaire Dryer, model #GLER341AS2, so I can replace the heating element?
  • Frigidaire Master
  • 7,482 Answers
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Frigidaire Gallery model Gler341AS2 drum is sagging towards 6 o'clock and causes a gap that snags clothes. What parts need checking to find the cause of this?
seals on front and back, but drum rollers/glides here is a website, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Apr 17, 2011 | Frigidaire GLER341A Electric Dryer
Dryer drum turns, no heat, replaced thermal limiter
Your model which we call the 417, is not usually easy to work on. The heating element is located behind the dryer drum. The drum has to be removed to change the element. There is a lot involved but given the cost of a stack unit the element and labor may be worth it.
Feb 17, 2010 | Dryers
Dryer squeals when i turn on. high-pitched squeak. very-loud
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 31, 2009 | GE DBSR453EBWW Electric Dryer
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Oct 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
When dryer cycle is done elements stay on
One of the switches that controls the heating element has not closed.
Apr 30, 2009 | Frigidaire Dryers
Trying to remove drum and how to check heating element on Frigidaire Dryer Model FER341AC0
You don't have to remove the drum to get to the heating element. Remove the cover at the bottom of the dryer, it should be on the right at the bottom.
Apr 11, 2009 | Frigidaire AEQ6000ES Electric Dryer
Put heating element in a frigidare dryer model gler341as2. will not run.
You will have to unplug dismantle and retrace your steps, it simply seems that one of your connections hasn't been completely made.
Jan 13, 2009 | Frigidaire GLER341A Electric Dryer
Dryer not getting hot
Bad thermal fuse or heating element
Nov 02, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLER341A Electric Dryer Logo
396 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
