Question about Kenwood KAC9105D Car Amp
Is the p.con the spot where i should hook up the remote wire on a kac9105d kenwood amp?
Yes it is. it runs to the blue and white striped wire coming off the head uni.
Posted on Apr 08, 2011
Kenwood kac-9105D amp
Tipical for that amp.Did you buy it used?
Oct 27, 2012 | Kenwood KAC9105D Car Amp
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a Kenwood KAC-9105D amp. It is brand new and worked for about 20 minutes while I was driving and it hasn't worked since. When I turn my car on, the blue and red LEDs on the amp both come on for a...
First of all, how are your subs wired to the amp. Make sure your amp is not bridged or you'll fry it, it only has one channel. If that doesn't work you probably already fried your amp.
Oct 09, 2010 | Kenwood KAC9105D Car Amp
My KAC9105D wont turn on? i had this amp stolen from me a week ago, purchased a new one and hooked it back up to the same wires that had been running the old one the exact same way, and it just lies there...
check your fuse on your power wire, should be under the hood by the battery. if the fuse is good then check to make sure you have a good ground and power on the remote turn on wire. it sounds like a blown fuse though, hope this helps. dave
Oct 04, 2010 | Kenwood KAC9105D Car Amp
No amp sound output
it might be ur ground check the gound wire
Jul 06, 2010 | Kenwood KAC9105D Car Amp
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Wired remote not working
Is kenwood deck known for this? I had the same problem with my kenwood, The only right way to fix this is try to get a new harness and see if it was the wire that was the problem, if this don't fix this, take it or contact your local kenwood dealer.. But if you want to be slamming now, this is what you can do. Have a power wire (with a toggle switch would be best) hooked up to the remote wire input on the amp, BUT if you don't unplug it the amp will have constent power, meaning your amp will stay on all the time. I just do this when i try trouble shooting, when my amp won't kick on, just to see if it comes on. Thats how i found out my remote wire on my kenwood was bad. Hope this was helpfull
May 13, 2010 | Kenwood KDC-MP228 CD Player
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC9105D Car Amp Logo
150 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
