Question about Wicor Industries # MP 1/2HP Sprinkler Pump
Need a gasket for a master/plumber 540003 1/6 hp
The gasket coming out of bottom of our sink erator was leaking and spewing. when we replace the washer before bolting on the gasket do we use plumbers putty?
Plumbers putty is for setting sink basket into sink.
I use rectoseal on all tubular washers and joints,
Smear it on thick and then assemble parts, and rectoseal ensures nothing will leak.
Dec 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Two rubber gaskets and a fiber gasket came with new strainer. do i use all the gaskets? what about plumbers putty
You are attaching sink strainer to sink opening.
1) Use plumber's putty. Finger-size roll of plumbers putty is applied around opening from top, or applied to the bottom of strainer basket. (Some sinks require silicone. Do not use silicone unless required by the sink manufacturer.)
2) Sink strainer is pushed into the sink opening, making sure it is centered and level.
3) From below, the rubber gasket is applied first, and then the paper gasket is second, and then the basket locknut.
4) Tighten locknut very firmly.
5) Wipe away excess putty on bottom.
6) Push down stainer from top again, and tighten nut some more.
7) Wipe away excess putty around bottom and top.
8) The cardboard washer lets the locknut rotate easily.
Dec 18, 2010 | Moen 22036 Stone Stainless Steel Sink...
Use foam gasket on sink strainer along with plumber's putty?
Usually the gasket is not foam but black rubber. There may have been a piece of foam as packing to protect the stainless. You would apply the plumber's putty directly to the sink. Insert the strainer directly into the putty, compressing the putty. Under the sink, remove the excess putty that extruded through the opening. Apply the rubber gasket to the bottom of the sink, and then the nut (sometimes a "cup" and then the nut) .When the nut is tight, remove excess putty inside the sink. LEAKPROOF!
Jul 06, 2010 | Franke Strainer Basket Sink Hardware
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
In sink erator is leaking from bottom
I had this happen right before my disposal stopped working completely. Mine was leaking from the same place. The one I had was a 2 year Badger. They are easy to replace. If yours still works I would keep using it and just sit a pan down below to catch water. A new Badger 1 year cost $80 at Home Depot. If you get one, do not worry about buying extra gaskets or the black sink strainer thing because the new one will come with everything needed except for the plumbers putty. You will need plumbers putty. Good Luck
Jul 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sewer pipe
Hi sir simon,
I'm Harvey the Master Plumber.
Your problem is: You're installing a new sewer pipe and wonderind how much fall it needs
1/4" per foot. You can buy a plumbers torpedo level to make it easy. You'll see 4 hash marks on the tube. Center the bubble in the middle and the pipe is level, so just adjust the pipe so that the bubble is just touching the outer line and you've got 1/4". No measureing. And it only costs a few dollars.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Plumbing
My cultery tray is broken and needs to be replaced. Where do I find a replacement?
Hi jneuman
Your question is; cultery tray is broken and needs to be replaced. Where do I find a replacement?
Easy! Just do an internet search for DISHWASHER PARTS.
You'll find lots.
Thank you,
Sep 11, 2008 | Dishwashers
Water leaks from door
Hi dec507,
Your problem is: you have a Caloric Model CD4 200 CWW and water leaks on the right side of the door. The gasket seem to be worn.
The gasket is easy to replace but you should also check the d/w for level. I mean horizontal, vertical and front back. Over time they can get out of level enough to cause a problem.
Thank you,
Sep 09, 2008 | Caloric 24 in. CDU210C Built-in Dishwasher
Wicor Industries # MP 1/2HP Sprinkler Pump Logo
Top Wicor Industries Garden Experts
Dennis Key
Dennis Key
john h
Are you a Wicor Industries Garden Expert? Answer questions, earn points and help others
