The speed control on my Izek has lost control. No matter what setting I use, it will spurt for a few stitches, then go back to normal and then repeats, eventually accelerating to the point where the machine stops itself. This happens with and without the gameboy and/or foot pedal. I've followed the other suggestions I saw here and oiled/cleaned the machine, but it is still acting up.
Have you tried removing the batteries and cartridge and re-intalling? Also I learned the pressure foot must be down for my izek to accept setting changes. Hope this helps.
To slow down the stitching speed on your Husqvarna Viking 18 x8, you can try the following steps:
Check the machine's manual: First, consult the manual that came with your Husqvarna Viking 18 x8 machine. The manual should have instructions on how to adjust the stitching speed.
Adjust the stitch length: One way to slow down the stitching speed is to adjust the stitch length. A shorter stitch length will slow down the machine's stitching speed. Refer to your machine's manual for instructions on how to adjust the stitch length.
Change the foot pressure: Another way to slow down the stitching speed is to change the foot pressure. Reducing the foot pressure can help slow down the machine's stitching speed. Again, refer to your machine's manual for instructions on how to adjust the foot pressure.
Use a different presser foot: Some presser feet are designed for slower stitching speeds. You can try using a different presser foot to slow down the machine's stitching speed.
Use a speed control pedal: Some machines come with a speed control pedal that allows you to adjust the machine's stitching speed. If your machine has a speed control pedal, try using it to slow down the stitching speed.
If none of these steps help slow down the stitching speed on your Husqvarna Viking 18 x8, you may need to contact a professional technician for assistance.
The start/stop button was pressed without connecting the foot controller while the setting for adjusting the stitch width using the sewing speed controller is set to [ON].
You have selected a pattern for which width control cannot be used.
Touch the icon at the bottom of the screen that looks like a sheet of paper. The screen that pops up should have a slider icon in the upper right. You can set it to stitch width or speed control.
There is no speed seperate control on overlockers other than the foot control but most sew at 1500 stitches per minute, very fast compared to sewing machines.
What is your stitch length set to as this could be the problem. For normal four thread stretch seam you would want the length set to beween 2 and 3 so double check this - the length knob is usually a knob on the right side near the flywheel.
Hopefully, the above solves the problem for you but if not, please message again.
