Question about Hobart AM14-253 Free-standing Dishwasher
My dishwasher hav problem...the water is not comming to dishwasher
    New Friend:
  • 43 Answers
First check water supply. Second check any voltage signal at solenoid valve. third check where the solenoid valve supply comes from?
Posted on Oct 18, 2016
  • 37 Answers
Could be a couple things first is water on.then check to see if sol valve is energizing start the fill cycle put a small screwdriver on the solenoid valve is it magnetized.if so check line strainer to see if it is plugged or valve could be limed up.if not magnetized coil could be bad,or could have got wet fuse might have blown.remember this is 24v coil I have seen some do it yourselfers put 120v coils on this will not work.couple things to check .need more info.
Posted on Apr 22, 2011
DD60DCW6 dishwasher i cant get out of area its in i hav draws out but rest wont budge
Dishwashers are usually bolted to the underside of the counter it is under. Open the front of the dishwasher and look up under the counter for two screws ... unscrew those and the dishwasher should slide right out. Once it is out a little ways you will need to siconect the water line from the unit. Be sure and turn the water off before unhooking it or you will flood the room. Usually the hose goes under the sink area and the water can be turned off there.
You will also need to turn off the power at the house breaker box so that you can disconnect the electric wire from the unit. If you are not familiar with household electric, you should call a professional for this.
Once the electric is disconected the unit should come the rest of the way out.
Nov 26, 2013 | Dishwashers
My dishwashere fills water even if i dont use it and i hav eo to drain water twice a week .
change out the water fill valve and this will solve your problem.
check the power and make sure there is no shorted wiring that would cause constant power to the fill valve.
Oct 13, 2010 | GE Dishwashers
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
My hotpoint aquarius dwf30 will not drain so will not wash...
Do you hear the motor run or is there deadly silence when you select drain.
Does the wash cycle start - do you hear water getting in and washer arms move?
Are there any lights flashing?
Jul 06, 2010 | Hotpoint 24 in. DWF32P Free-standing...
Hi I have a Whirlpool dishwasher Model #DU912PFG01 Or DU912PF001 or DU912PFGG1 cannot tell the last 3. Serial # FK194309. My son noticed the dishes didn't look clean, he added DISHSOAP which then produce a...
Slog builds up in the drain pipe right before the garbage disposer. I had to replace mine when I replaced my old dishwasher. If you put vinegar in the dishwasher to unplug the pipe, the vinegar could have loosen all the slog and clog the drain pipe just like a built up in the hurt artery.
Sep 04, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Bosch Dishwasher low water problem
The water level is actuated by pressure to the level switch.this is transferred by a plastic hose from the sump in dishwasher up to the level switch. the hose could hav excess fluid in it or be partially blocked. Try removing and emptying this hose of any fluid or gunk, Note when refitting it pays to cut snall amount off both ends of hose by about 3/8's of an inch so it fits back on tightly. If you dont do this it might leak and cause dishwasher to overfill. If this doesn't work the next step is to try and replace level switch.
Aug 17, 2017 | Dishwashers
Hot point dishwasher
your always gone hav a small oamount of water in machine after cycle is complete never can totally remove all water. not to worry though before running next cyclye the dishwasher first redrains and then fills
Mar 02, 2008 | Dishwashers
Bosch diswasher
check heater element for open circuit, if the dishwasher fills and empties and wooshes the water round, there is little else to go wrong
Oct 05, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher will not drain
I hav an Americana / GE dishwasher, only one and a half years old. the dishwasher is not draining. When I turn the selection knob on the front to wash, is begins filling with water again. But, the cycle is not actually working. I removed the drain hose from the disposal unit and allowed the really really nasty collection of water to drain out. I have a feeling that the hose connection to the washer is clogged. Is this possible. If so, should I remove the hose from the connection at the dishwasher and clean the hose or could it be something else.
Thank you,
Aug 31, 2007 | GE 24 in. GSD4320Z Built-in Dishwasher
Spray arms
Sounds like the circulating pump is faulty or the spray arms hav become partially clogged. Loss of available water will stop the spray arm motion.
Feb 05, 2007 | Kenmore 16872 Built-in Dishwasher
Hobart AM14-253 Free-standing Dishwasher Logo
125 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
