Question about Whirlpool ET8CHEXSQ Dryer
ALL WORKS BUT DON'T DRY - Whirlpool ET8CHEXSQ Dryer
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
Tip
Preparing a screen for silk screening
Printing your own shirts at home is fun but can also be a long and tedious task, especially if you don't do things properly from the beginning. But when done properly the final results can be very rewarding.
First you have to make sure that the screen is completely dry so if you are washing your screens then you have to wait for them to dry. I like to stand them up in front of a fan for a few hours you can usually tell if they are dry the screen itself has a slight change in color in spots that are wet, you don't have to wait for the frame to be 100% dry but I like working with metal frames because they don't absorb water like the wooden ones. Once the screen dries then the fun begins.
Take your screens in to the dark room and if you have dark room lights (the red ones) then you can turn one on but try to keep the emulsion away from the light. Pour some emulsion into your coater you don't need a lot of emulsion if you are only doing a few screens. Holding the screen with the back facing you (the side that is flat) at about 110* angle in one hand and the coater in the other tilt the coater so the sharp edge is flush with the screen. I like to hold the screen in my left hand and the coater in my right because you need to apply a little pressure on the screen with the coater and I have more control when I use my right hand.
When you see the emulsion coat the whole edge of the coater and bead up at the sides a little you slide the coater up the screen in one even motion. It take a lot of practice to get a nice even coat. When you reach the top of the screen tilt the coater back so the emulsion goes back into the dish. Push up a little more and pull the coater away from the screen then flip the screen and repeat the same motion on the inside of the screen. If you didn't get a nice even coat like if towards the top the emulsion thins out and disappears this means that you didn't have enough emulsion in the coater but there is nothing you can do but work around it. Don't re-coat an already coated side!
After you coat a screen lay it on a drying rack with the flat side down, make sure that nothing touches the emulsion while it is wet and that no light gets on the screens until you burn them (put the design you want to print on the screen). Allow the screen to sit in the dark drying for at least 24 hours of until dry. If you coated the screens evenly then you shouldn't have to worry about dripping, but if you didn't then you might have to wait a few minutes between coating screens to make sure that they don't drip on each other.
on Sep 24, 2013 | Crafts & Hobbies
How do you eat freeze dried food?
You don't need to do any cooking to prepare freeze dried food. You just add hot water and wait 10 minutes. If you don't have any hot water you can use cold water to prepare cold food.
Aug 13, 2012 | Camping, Backpacking & Hiking
How to dry out an ipod
Put it in a warm sunny place for several days. Don't forget yo turn it off.
If it still does not work after drying out then you need a new IPod.
Feb 26, 2012 | Apple iPod touch
I dropped camra in water any way to dry it out
I dropped my cell phone in water one time and somebody told me to put it in a bowl and completely cover it with dry rice and believe it or not that worked. Don't usually answer camera questions but thought I may try to help. Give it a shot and I hope it works for you.
Jan 30, 2012 | Cameras
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
I have 1998 bmw 323 the rag top has a few small snags in it. No tears just small snags that I dont wanrt getting worse.
If you don't want to hand sew the top then cloth adhesive will work to keep loose end from unravaling further. depending on the fabric and color I like a very small amount of either goop, contact cement, or a very small amount of superglue. for best results make a small repair in a not to noticable place and let it completely dry. then see what it looks like. if you don't like it don't do that again. Sometimes with contact cement you can hand mold the loose pieces after the glue starts to dry. goop dries a little quicker so you need to work pretty quick. superglue is the hardest to work with but done carefully it will give you the longest lasting and least showing result. be extra carefull not to get the glue on anything and make very small repairs one at a time.
Apr 23, 2011 | Car Audio & Video
Accidental Damage !?
dry it completely ... definitely t'l work atleast after two to three dyas ... don ever be in hurry and give it to service center ...
Nov 20, 2007 | Nokia 6300 Cellular Phone
Odder phones don?t listen to me
hi,
 u just do one thing open the hndset again & put in the sunlight for approx 2-3 hrs & dry up in that ..it will remove all the moisture from ur hndset & it will wrk properly
Thanks
Gizmo11
Oct 21, 2007 | Nokia 6020 Cellular Phone
Whirlpool ET8CHEXSQ Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
